YO,
Just stripped my Fox Fork Lowers Disc Mount… What size helicoil did you use, where did you buy it and how did you do it!!!
So pissed at myself,only reason it happened was that i was prepping bike for Scottish champs tomorrow, when my pads fell out of my Stroker trails front brake, along with the piston / pad connector pin. So i dug out my wife’s old juicy caliper onto my Stroker lever and it worked, went to put the caliper onto the forks and it was a bit of a fiddle as Juicys are, to get aligned. I tightened and loosened too many times and stripped it! completely my own fault.
What makes it worse is that I just put brand new 2012 Xt’s on my wifes bike and she came home two days ago with it in bits in her pocket having come off and obliterated the right lever on some rocks! So were not having much luck here.
