Anyone come up with any way of spreading the beam?
Bike Forum
diffusing the DX Bastid light?
Posted 7 months ago #
I put a piece of opaque plastic bag over the lens. (unscrewed the crown, put it over the lens then screwed the crown back on)
Probably a major fire hazard but seems ok !
Posted 7 months ago # -
i have one of the ebay jobbies - works a treat
magic tape / scotch tape. just stick it on the inside of the glass to make it opaque
Does anyone know if that ebay diffuser will fit the T6 XML Bastid?
NW, measure your lens, see if it is 39mm as it states it will fit all 39mm lenses.
Are they all the same depth for hte bastids? I've got 2 39mm lenses here but they don't both fit in the light, one is much deeper than the other.
I've popped one of those on the T6 XML, fits fine and does help widen the spot fairly well. Only tricky bit is getting it perfectly straight when tightening everything up
Grand... Thanks very much for that, I'll get one ordered!
Andrew
forgot to say there is also this guy:
Anyone know if there exist wide-angle attachments for lenses with a 34mm diameter?
Nice, seems worth a shot, cheers
Reply
You must log in to post.
