Custom decals quest...
[Closed] Custom decals question
[#3196242]
I know a few of you have done this, so thought I'd ask here.
If i'm getting a decal printed which consists of just a word (no graphics) should I:
- get each letter cut separately and stick them on individually. How do you make sure the word stays in alignment?
or
- get the word printed on clear vinyl as one block. Will I be able to see the clear bits once its on?
Whats the best method in your experience?
Thanks
Amit
Posted : 29/09/2011 4:26 pm
When I had some printed the vinyl is between a paper backing (sticky side) and a clear top layer, peel off the paper, stick onto the frame, peel off the clear layer, just like puncture repair patches.
Posted : 29/09/2011 4:29 pm
thisisnotaspoon, where did you get them printed?
Posted : 29/09/2011 4:30 pm
Anyone else had custom decals printed?
Posted : 02/10/2011 7:56 pm
yes speak to Gil gil@thecycleshed.co.uk
Posted : 02/10/2011 9:51 pm
Anywhere that cuts vinyl for decals will apply a backing. Its semi transparent so you can still see where its going. Apply, give it a rub and peel off backing! Simples....
Posted : 03/10/2011 2:07 am
Agreed, then each letter will be put on individually then they can be sealed with a clear coat.
CCA signs did ours...font and size of our choice...
http://www.cca-signs.co.uk/
Posted : 03/10/2011 7:47 am
 gil_
Totally depends on size of text and also colours used and number required to a degree
Normally something with a letter height above 10-12mm would be a pre-spaced cut vinyl, this comes with an application tape so no need to fit single letters, all fitted in one section
This is durable and can be clear coated if you wish as long as the frame is not oven baked to cure the clear coat
Lettering smaller than 10mm or with fine detail would be printed onto a clear base and cut to a 2mm outline profile, same as above applies for clear coating
Lots of other options, drop me a email for more info 🙂
Posted : 03/10/2011 10:04 am
Thanks Gil, will email you the illustrator file tonight...
Posted : 03/10/2011 12:55 pm
