Hi
I have had my Cube AMS 125 ‘the one’ for about a year, i take it out about three times a week. mostly around the hills and mountains of south wales, including the usual trail centres.
you get a lot of bike for the money, but i think you should think about what sort of bike you think you are getting for the money.
All Mountain? the spec would suggest so, with the 140mm Fox FIT Talas fork, Fox RP23 boostvalve shock, Formula ‘The One’ brakes and DT swiss wheels……however, the geomtetry is more xc….this is not to say it wont handle AM, it’s just not very forgiving geomtetry, steepish head angle and tall stand over and looooong stem…..i have pimped mine a little, with 60mm stem, KS 125mm drop seet, Shimano DX pedals, Maxis Minion Tyres and a recent addition, the Cane Creek Angleset to slacken things up a little.
it’s handled everything i dare point it up and down….with some coaxing….
it’s the little things that have bugged me: cable routing is diabolical..namely under the top tube towards the seat post, where the cables appear and are routed to the rear brake and gear selection…cables and frame get severly rubbed here…keep an eye on it! i have used frame protector to minimise damage….the down tube is easily dinged! so much for triple butting, strong at the joints, wafer thin walls everywhere else. the chainstay takes a beating too, so protect with the usual.
i have regularly serviced the bike, and recently replaced all suss linkages…..
the strong points of this bike are the components….to the point that i will probably wear out this frame this summer and buy a second hand zesty to transpose the components!
all mountain? borderline! beefy XC? most probably!
