Connector PIN
[Closed] Connector PIN
[#843982]
How many Shimano connector pin's can/should you use in a chain.. ?
Posted : 06/09/2009 8:39 am
 nuke
There's no limit to the number you can/should use but the correct answer is none, you should use a powerlink 😉
Posted : 06/09/2009 8:44 am
SRam & Shimano is that compatible.. I already used a conneX link it's a bit of a mess 😕
Posted : 06/09/2009 8:47 am
 nuke
[i]SRam & Shimano is that compatible[/i]
Yep, for 9speed get the gold ones. Being using them for years on Shimano chains with no problems.
Posted : 06/09/2009 8:49 am
I had a bike in for servicing that was running fine with 9 powerlinks!
Posted : 06/09/2009 8:51 am
in theory could you not construct a whole chain of powerlinks? if its strong enough in one place surely its good enough for the whole thing....
Posted : 06/09/2009 8:52 am
Sweet! no new chain then..
Posted : 06/09/2009 8:54 am
