I need some new chainring bolts for my SS and had a question. Can you get bolts that dont require a peg spanner to tighten at the rear, say use an allen key instead, or is it peg tastic all the way?
The reason I ask and the reason I need new ones is my last set fell of resulting in a near groin stem interface and a craccked chainring.
They were aluminium bolts which I'd tighten as much as possible with my peg spanner but had somehow managed to work themselves loose quite dramatically.
Maybe loctite them in would help but then would they come out after is the question? On my triple XT I used loctite after changing rings but when I went to replace them the bolts had siezed.
Any thoughts appreciated
