chainring bolts for...
[Closed] chainring bolts for 1x9
[#2184883]
So if you remove the outer ring then the chainring bolts for my 1x9 no bash setup are too long, where to get shorter ones?
Has anyone used [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=19227 ]these[/url] or [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=7064 ]these[/url]? Or anywhere else? (Cheaper...)
Posted : 13/11/2010 12:01 pm
Try Charlie.
http://www.charliethebikemonger.com/userimages/procart4.htm
Posted : 13/11/2010 12:13 pm
You could just get some spacers, that way you can adjust the chainline better. I got mine from Charlie the bike monger, Velosolo is also quite good.. Or you could just get a bash ring to replace the big ring you removed.
ok gone with charlie thanks.
Posted : 13/11/2010 12:28 pm
