What chain guides are folks using on their BLUR LT2s. Im thinking about getting rid of the triple and sticking on a 36T but it looks like it might be a bit cramped with the virtual pivot design. Just wanted to see what works and what doesn't. Im thinking about a Stratline silent BTW.
Bike Forum
Chain guide on a BLUR LT2??
Posted 8 months ago #
Can't speak for the straightline but I run an mrp g2 mini, works perfectly with a 1.5mm spacer behind the chain device. Pretty much silent and zero rub. No modification either
Posted 8 months ago # -
I;ve got a lt2 with 1 x 10 set up.I'm using a gamut g25 but youv'e got to grind down the lock nut on the btm roller to about half it's depth so it clears the link.after all it is just a lock nut as the bolt for the btm roller is threaded in the back plate.Igot mine down to thickness using a belt sander and 60 grit paper.
Rob what's that like with the coil? I was thihnking about getting one for mine.
If your going to run just the one chain ring up front you have a few to choose from..
but if its a double bash you want to run then things get a bit more tricky, i dont have a blur but ive had the old tracer and now have the new one, as youll probably know they share the same VPP suspension, the only one i could get to work was the Blackspire Stinger, but it has to be moded and its a bit of faf but it can be done, its tight with clearances and you dont get a lot of tension, but it works enough to keep the chain on....
here is a link for some info on it
Bash infoPosted 8 months ago # -
thanks for the replies folks. Il look into all options. might need to head down to the bike shop and have a play about with some old ones they have lying about. any other advice welcome
Reply
You must log in to post.
