CCDB Inline
[Closed] CCDB Inline
I was advised this too. I weigh 85kgs and was told that 80kgs was the cut off that they would happily sell an inline. Changed order to ccdb air.
Posted : 19/08/2014 6:34 am
^^^ didn't know about the 80kg thing...best not be putting too much weight on then!
Was thinking of ccdb air cs...but thought it was a bit overkill on 130mm bandit. Plus its £100 cheaper.
Posted : 19/08/2014 6:48 am
 poah
ha I'm 80kg that kinda worries me.
Posted : 19/08/2014 7:13 am
I had the phone call last week (I'm about 85kg) and I was grateful for not being sold something that might not be suitable.
I sourced a used CTD Kashima shock and i'll be getting this Pushed instead.
Posted : 19/08/2014 7:41 am
The ccdba cs is great. You bigger gentlemen should consider that.
Posted : 19/08/2014 7:45 am
 sv
Oh ffs, good price too grrr.
Posted : 19/08/2014 11:20 am
Well if anyone finds themselves with a 200x57 they're too heavy for... 😉
(that is really pretty low isn't it, kind of shocked at that)
Posted : 19/08/2014 11:24 am
80k? I'll need to cut a bloody leg off!. :mrgreen: 😳
Posted : 19/08/2014 11:46 am
About 5 rides or so into mine and it really is a fab shock that walks all over the stock CTD that came on my bronson. Fast descents on my regular loop before that felt like it was really at edge of fox's control just feels so controlled now. Really smooths everything out but not in a numb way, great traction as well over some lumpy across ways trails that we ride. My only issue with it that tftuned say is normal is an initial lump you can feel in the shock. Apparently all cane creeks do it yet the OH has the db air cs and you cant feel it at all! Might consider sending it back if it plagues me but as I cant feel it when i ride and can only feel it when settling into the sag I may just ignore it and follow their advice.
Posted : 19/08/2014 11:54 am
I rang this morning to check availability - all I was asked was the psi of my existing shock. I might have to give them a ring back.
Posted : 19/08/2014 12:07 pm
Hmmm, I weigh around 85kg but only run around 160psi in my shock, might have to give tf a call
Posted : 19/08/2014 12:23 pm
TF Tuned were very helpful on the phone. If you have any doubts about the suitability of the shock just give them a call for some expert advice!
Posted : 19/08/2014 12:24 pm
It's the PSI you normally run that is the problem. Anything around or over 200psi and it's not currently going to work. I weigh over 80kg but only run 170 in my current Monach and have been told this is fine. Should receive it tomorrow 🙂
Posted : 19/08/2014 12:27 pm
 poah
Juat off the phone about mine - only run 150 psi in my monarch plus, so with my weight and bike it should be fine. shock will be arriving tomorrow and I bet it will come when I go to get the kids at school lol
Posted : 19/08/2014 12:48 pm
Stop posting all this praise, I must resist 😀
Posted : 19/08/2014 12:58 pm
Hi Guys,
Just to give you an update on the DBinlines. We have more sizes in stock now (216x63, 200x57, 200x50 & 190x50. They are a great looking shock and having prepped and sent out over 30 units (including lots of local riding on our in-house demo shock!) we can safely say that Cane Creek have produced another great piece of suspension at a really competitive price point for the trail/ enduro market.
Those of you that have spoken to us about your orders will be aware that certain combinations of rider weight/ suspension design requiring air pressures over 200psi do not allow the high speed rebound damping to work as effectively as we would like it to. If you currently run around 200psi in your shock then you may fall into this category.
We’ve spoken to the technical guys at Cane Creek and they are in the process of sending us some additional parts which will allow us improve the tune of the DBinlines at higher pressures. In the meantime if you have questions about an existing order, or want some advice as you are thinking about ordering an Inline, then please do call us.
Cheers TFT
Posted : 19/08/2014 1:35 pm
@Northwind
Early puff pieces suggested the "head" was rotatable, so instead of having the controls sticking out the side like prince charles' ears, you could have it all nicely turned to one side. Better access for the CS lever too. Anyone know if that made it into the real world?
I seem to remember that this was touted as an option for OEM shocks to provide better accessibility but after market shocks would be fixed in the normal position. Neither version could be moved from its factory set position. I also think that the OEM versions could have the CS tuned to different levels depending on he bike but again after market would be whatever the factory tune was. But this is from memory so may not be entirely correct.
Posted : 19/08/2014 1:46 pm
Ah, that rings some bells Shackleton. Shame, it'd work better in my bike at rightangles I think. Cheers!
Posted : 19/08/2014 2:11 pm
Weighing 100kg kitted up counts me out on the dB inline then? Was going to get a rockshox rc3 plus debonair.. But no stock.. Looks like its the CCDB air CS. Only thing I don't like is the weight..
Shame as I thought the dB inline would have solved that minor issue.
Posted : 19/08/2014 5:10 pm
 LeeW
I think the answers are above, it depends on what pressure you run in your shock.
Posted : 19/08/2014 5:13 pm
LeeW
My CTD on my anthem from tftuned is running 250psi..
For my new orange build I don't know what pressure I'll be running the shock at.. Its not been ridden yet.
Posted : 19/08/2014 5:24 pm
TF may not thank me for posting this but I spoke to them earlier, not going to say who to. Guy reckoned that the inline would be subject to some significant revisions and that he wasn't convinced by it yet, he thought the fact that it can't cope with higher pressures indicates that it hasn't had enough testing. He recommended waiting for gen 2 and that I would be better off having my 2012 adaptive logic rp23 pushed with boost valve removed. Think I'm going to wait and consider my options for a bit.
Posted : 19/08/2014 5:52 pm
Is there a similar limitation on the normal dbair? Obviously not as low as 200psi, but 250 for example?
Posted : 19/08/2014 6:08 pm
3 years in the making and not enough testing?
Posted : 19/08/2014 7:09 pm
I'm only going on what he said but the fact that the damping can't cope with high pressures seems a bit telling. Or maybe they know they'll sell as many as they can get in at the moment and are trying to steer some people to other profit makers, higher margin on a push tune perhaps? Hard to know but the guy seemed genuine, obviously a keen rider.
Posted : 19/08/2014 7:21 pm
80kg weight limit is really low - I'm 6'5" but skinny as hell but over 80 kg in kit with camelbak
Posted : 19/08/2014 7:26 pm
 sv
Ordered one earlier (typical!), over 80kilos but shock runs lower than 200psi so we will see. Bit of beta testing never did anyone any harm...
Expect the 'it's blown up and taken the nursery school/village hall/local creche with it' story next week/month 🙂
Posted : 19/08/2014 7:47 pm
bit worrying as I have a frame set on order with this shock supplied by the manufacturer I think. I'm just over this weight and whilst I run a rp23 at 160psi now that's irrelevant as sag will need to be set relevant to this frame and this shock. So who knows what pressure I'll need until it arrives.
I've not seen any such reports on mtbr or any other yankie sites and they've been shipping DBinlines a while and dare I say will probably have their fair share of larger bikers?
Posted : 19/08/2014 9:09 pm
Also what about manufacturers speccing them on bikes, Canyon, Specialized etc. Would they move to Cane Creek shocks if they thought they had a pup on there hands?
Posted : 19/08/2014 9:12 pm
TBH it could easily be TF's high standards- let's be honest, tons of people will sling an expensive shock on and never even really bother to set it up right, let alone worry about whether the damping works well for their weight.
Posted : 19/08/2014 9:53 pm
Not enough rebound damping is a pretty vicious vice for a rear shock to posess though - in terms of being launched over the bars potential!
Posted : 19/08/2014 11:16 pm
 poah
mine arrived - drive way test after setting sag is significantly smoother than the monarch plus that was on it before. will have to wait to test it later tonight.
Posted : 20/08/2014 3:28 pm
@poah- I wonder, could you do me a wee favour and measure the width of the head (controls end) please? This is stage 3 of "failing to talk myself out of it"
blacka01 - Member
True that... I got the impression it just performs badly, rather than lacking damping?
Posted : 20/08/2014 3:31 pm
7cm.
[URL= http://img.photobucket.com/albums/v444/RickDraper/Cycling/AB4ADE53-6B76-44CC-A203-18B5784C683C.jp g" target="_blank">http://img.photobucket.com/albums/v444/RickDraper/Cycling/AB4ADE53-6B76-44CC-A203-18B5784C683C.jp g"/> [/IMG][/URL]
Here is mine on my Solo:
[URL= http://img.photobucket.com/albums/v444/RickDraper/Cycling/CE68D1AC-A64F-4382-A43A-21A2234BB867.jp g" target="_blank">http://img.photobucket.com/albums/v444/RickDraper/Cycling/CE68D1AC-A64F-4382-A43A-21A2234BB867.jp g"/> [/IMG][/URL]
Posted : 20/08/2014 4:00 pm
Just away home from work to open mine and fit it. Apparently the wife say "it came in a cool parcel." No idea what that means?!
Posted : 20/08/2014 4:24 pm
 poah
brown paper with TFtuned tape round it. nothing fancy about it
Posted : 20/08/2014 4:41 pm
I'm teetering on the brink and I think I'm gonna fall.
Anyone used one with a Pike (ideally on a 4-bar bike)? Wonder if they make a good match?
Posted : 20/08/2014 4:50 pm
matther01 - Member
It means "I deserve something shiny too"
Posted : 20/08/2014 4:58 pm
I have no need for this shock.
With my lack of ability I doubt I will notice the difference between this and my ctd.
I should be spending money on real life items.
I don't need one.
Please someone say it's rubbish.
Posted : 20/08/2014 4:59 pm
chakaping - Member
I'm somehow managing to stay strong but not sure how long it's going to last!
Done it.
Posted : 20/08/2014 5:07 pm
You're worse than me [b]chakaping[/b] come to the lakes to test it out
Posted : 20/08/2014 5:20 pm
As soon as the opportunity presents itself, I plan on doing just that.
Posted : 20/08/2014 5:30 pm
George - it was wrapped in pictures of shoes from a magazine...I've gotten the not so subtle hint!
Its also taken my ten mins just to get the bloody zip ties of the shock ends without damaging anything...grrr
Posted : 20/08/2014 5:47 pm
is it just me, or does the ccdb inline look like Mr Spoon?
Mr spoon
/p>
A ccdb Inline
Posted : 20/08/2014 5:53 pm
Page 2 / 5
