Camelbak bladder - ...
[Closed] Camelbak bladder - a strange thing has happened
[#733164]
I have a Camelbak 'pureflow' bladder and it has been leaking. Double checked the seal was tight enough and that all looked fine. I removed the bite valve for washing and then noticed that the inner liner had wrinkled so bite valve wouldn't fit flush.
This appears to have a lifetime warranty so I will put this to the test. Has anyone else had this happen?
Posted : 24/07/2009 2:39 pm
Nope but my bite-valve leaks so I've always gotta shut the lock thingy or I get soaked
Posted : 24/07/2009 2:41 pm
 Olly
platypus bite valves are a billion times better.
a billion!!!
Posted : 24/07/2009 2:44 pm
I think you'll find that they are 1 less than a billion times better but I've no idea what that number actually is.
Posted : 24/07/2009 2:47 pm
I use a locking one with a cover. Are bite valves interchangeable?
Posted : 24/07/2009 2:49 pm
I've had this happen, I used to have a backpack that I couldn't get the bite valve and lock-off through the hole in the pack, so had to remove it every time I used it (to fill and empty). Mine was an older camelbak which didn't have the lifetime warrenty (or so I thought?), so I first cut of the offending piece of tubing pas the issue but eventually bought a new tube.
Posted : 24/07/2009 3:02 pm
FYI, the warranty is for the lifetime of the [b]till receipt[/b], which given their eminent losability and thermal printing is not long 🙁
Posted : 24/07/2009 3:45 pm
Yes mine did this.
I now have a deuter streamer bladder. Instead of a screw top (which I always found quite strenuous to open), it has a fold over bit then a slidey thing.
The end also has a cover for the bite valve, which won't fit through the holes of the old camelbac easily. I prefer this version.
Posted : 24/07/2009 4:22 pm
no, but it's happened in a part of my tubing and makes it hard to suck through.
Posted : 24/07/2009 4:38 pm
CG i had problems with my bladder as well !!!(ooh matron ) e mailed Zyro the importer (mine was leaking around the filler cap ).they told me to take it to LBS ( i bought it in the states 4 years ago )just been in now and they have replaced it FOC .really didn't fancy paying £25 for a replacement .Just found a spare bite valve that might do at a push for the weekend .Do you want me to bring it with me ? I'll stick it in some Miltons if you want it .See you tommorow !!!
Posted : 24/07/2009 4:41 pm
this happens to me every few months or so, and I just cut off 1cm of tube to get a clean end again...
Posted : 24/07/2009 4:45 pm
So how long will it take until your tube is too short to use?
Posted : 24/07/2009 5:35 pm
oldfart - thanks very much but it's actually the tube. See you in the morning!
I guess I could give it a trim as sfb does.
Of course I could have invalidated the warranty by using energy drink and thus contaminated the plastic 🙄
Thanks for the replies everyone 🙂
Posted : 24/07/2009 6:07 pm
 nbt
My LBS sent my bladder off to the wholesalers when it developed a leak - I paid for postage as I not only didn't have a receipt, as far as I could remember I hadn't bought it from them. Got a replacement bladder back a week later, with my lockvalve in a little plastic bag as they don't come standard one new bags.
CG, let us know if you do try for a warranty, I have a tube that seems to have done the same thing - I swapped it out for a spare tube that I have. the delamination appears to have spread quite some way down the tube though
Posted : 24/07/2009 10:27 pm
I've never had anything wrinkle, don't even know what you are talking about. Wtf are you drinking?!
Posted : 24/07/2009 10:38 pm
nbt - I use a lockable valve and that fits outside the tube. The standard bite valve fits inside the tube. Hmmm, could Camelbak wriggle out of this one 😉
molgrigs - nothing wrinkle you say? Lucky you 😉 I've been drinking red wine, how about you?
Posted : 24/07/2009 10:49 pm
once the tube is too short (2 more years ?) I have plenty more from leaking pre-lifetime warranty bladders:-)
I've never had water in mine, I always have squash 🙂
Posted : 25/07/2009 6:27 pm
