I'm sorry to have to post this but can anyone give me a clue here?
Got some Deore hydro brakes and on the front (post mount) caliper the outermost pad is rubbing on the rotor, which itself is pretty straight. Trouble is this happens when the caliper is secured as far away from the hub as possible and no amount of piston re-setting remedies it.
So, to my mind, somehow I either need to get the rotor closer to the hub or the caliper further away from the hub in order to stop the outer edge dragging. Am I missing something here or is there a solution? TIA in advance and apologies for another caliper alignment thread.
