Cable Zip Tie Quest...
[Closed] Cable Zip Tie Question
[#282269]
Hi,
I've seen Zip Ties that our like a double, in that one part of the zip tie attaches say to the frame, and second part attaches to say the gear cable. A bit like a figure of eight. I hope the explanation is clear. I realise I could use two zip ties, but I want, and have seen a zip tie which is a single item.
Any ideas where I can get them from?
Thanks Wipeout
Posted : 06/02/2009 7:52 pm
You just need a tiny bit of tubing to form the 'waist' of the figure-8. A bit of plastic cable endcap works a treat. The tie goes through the tubing, around the cable, back through the tubing and then fasten around the frame.
Posted : 06/02/2009 8:01 pm
We buy cable ties from a company called http://www.hellermanntyton.co.uk/
you could try asking them
Posted : 07/02/2009 11:14 am
As above, chop the end off a cable end cap, push zip tie through cap, round cable and back through end cap, then strap to frame. Its a tight fit but is neat and holds the cable away from the paint 🙂
The other method is to get a 10mm long piece of clear tubing (such as fish tank airline) thread it over brake hose/gear cable so its alongside the headtube, then run a strap through the tubing alongside the cable and then round the headtube just above the lower headset cup. This is a bit more fiddly as you have to remove the cables to do it...was on my list of things to do for ages until I wore through my rear brake hose and changed them for braided.
Posted : 07/02/2009 11:59 am
I use them at work
http://shop.comdir.co.uk/Products.aspx?intGroupID=1616&strProductID=tgnjcstesu&strWebTemplate=C
Google "double headed cable tie" & you may find somewhere that will sell them separately
Posted : 07/02/2009 12:06 pm
86p for a pack of a hundred - hardly worth trying anywhere else?! 😆
Posted : 07/02/2009 12:54 pm
£20 minimum order 🙄
Posted : 07/02/2009 1:18 pm
That might be a pricing error black and natural ties are usually the same price.
Posted : 07/02/2009 1:35 pm
