Building your own w...
[Closed] Building your own website browser question.
[#2653386]
I am in the process of building a website using a 'build your own site' on-line tool. It just about looks okay but when I link content to an external site it won't display unless I adjust the security settings within IE. I do get the message about displaying non-secure content but it won't display even if I say I want to display the content.
It works fine in Firefox and Opera so is this a glitch with IE or is there something else I am missing?
Posted : 12/04/2011 10:47 am
Welcome to the world of web dev, IE is NOT your friend!
Posted : 12/04/2011 10:52 am
you have dicsovered the programmer's phrase: 'it works on my machine'.
it will serve you well
Now try: 'let's run it again and see if it does the same thing'
Posted : 12/04/2011 10:59 am
Our web dev here spents about 70% of his time fixing IE specific bugs in our web app.
Posted : 12/04/2011 11:02 am
 nbt
sounds like your site is delivered over https and you're using an iframe to deliver http content, or maybe vice versa on the protocols. theoretically it's a browser setting but in practice it's probably the way you're doing it. Without further details though...
Posted : 12/04/2011 11:14 am
The problem is that (according to google analytics on all the sites I've done) most people who will view the site will probably be using IE, hardly anyone will use Firefox, Opera or even Safari.
Posted : 12/04/2011 11:26 am
That's pretty interesting, no-one I know uses IE anymore.
Posted : 12/04/2011 11:48 am
 nbt
Most corporate stuff we do is IE.
Posted : 12/04/2011 11:50 am
I see, where I work (pretty big place) allows its users to pick what they want to use (and supports any of the main browsers). I have worked in companies in the past where it was "you will use this".
Posted : 12/04/2011 11:52 am
coffeeking - Member
As _tom_ says most people use IE. If you look at any hosting stats people using IE vastly outweigh any other browsers put together!
nbt - it is an iframe delivering http content. Is there a way around it?
Posted : 12/04/2011 11:55 am
 nbt
We have free choice here, but when we do work for clients - and internal clients - IE 7 and upwards is on the list.
 nbt
ok, the problem is there's a clash between HTTPS and HTTP. WHy are you using HTTPS?
Posted : 12/04/2011 11:56 am
Not sure, it is probably the way the build your own site has been set-up - I will investigate!
Posted : 12/04/2011 11:59 am
