Bugger! Banjaxed Ce...
[Closed] Bugger! Banjaxed Centre lock over zealous DIY horror
 2bit
[#1064414]
In my frustration with my 'rockin back n for Planet X superlight 29er wheel' I seem to have overtightened the centrelock lock ring & looks like I've snapped off the flat ring 'head' component leaving the thread in the barrel.
Total **** I know but any ideas?!
Theres no purchase on the broken thread at all so its stuck n screwed into the hub.
Have I totally f$£%£ed it?
Posted : 22/11/2009 9:55 pm
With the head part sheared off the thread part should be inder no tension so should be easy to turn. I say should 'cos things don't always turn out like that.
Can you drive it round with a punch? wedge something in to turn it? weld bit of steel onto it?
Posted : 22/11/2009 10:10 pm
Dremel.
Posted : 22/11/2009 10:20 pm
 2bit
No welding or dremel but fingers crossed its not tight - I'll have a go with wedging something in there
Posted : 22/11/2009 11:15 pm
Any luck?
Posted : 23/11/2009 9:58 pm
