Brewers of STW
[Closed] Brewers of STW
[#9144194]
Following on from the Massive Brewery thread, I think we've got quite a few brewers on here.
I've been sharing stuff by email with a couple of people and thought it might be worth starting a thread with recipes etc?
I'll start with a few of my favourites (all on beersmith since I use that software):
[url= http://beersmithrecipes.com/viewrecipe/1645/bells-two-hearted-ipa ]Bells Two Hearted IPA[/url]
The original that this clone is based on is widely regarded as the greatest IPA ever produced, but you'll struggle to get a hold of a bottle. I've had a bottle before, but it was a long time ago, so I can't comment on how close it is to the original, but others have said it is. Regardless, this still remains the best beer I've brewed and is honestly one of the best beers I've tasted! The only adjustment I made in my second batch was to reduce the dry hopping time to one week, since there was a very slightly grassy tinge when sticking them in for the full 14 days. I just dry hopped straight into the primary after fermentation was complete.
[url= http://beersmithrecipes.com/viewrecipe/16419/anchor-porter-clone ]Anchor Porter clone[/url]
One of my favourite porters. This clone is remarkably close to the original. Don't be fooled by the basic recipe, it's brilliant. I used an english yeast on my first batch and a US yeast on my second. The english yeast gave a fruitier flavour, which isn't my cup of tea, so I prefer the US yeast. I left in primary for about 3 weeks then bottled.
[url= http://beersmithrecipes.com/viewrecipe/324446/sierra-nevada-pale-ale-monster-5-gal ]Sierra Nevada pale ale[/url]
One of the first brews I did, simply because the original is so identifiable, I thought it would be a good way to benchmark my brewing. This clone turned out really really well. A little bit more bitter than the original, but in a side by side test they were surprisingly close. I'd lighten up on the crystal next time since it came in a little bit too dark.
[url= http://beersmithrecipes.com/viewrecipe/17432/citra-double-ipa-clone-kern-river-brewing-company-cybi-podcast-version ]Citra Double IPA[/url]
This one is still a bit too young for me to comment conclusively, but I honestly think it will surpass Bells Two Hearted as my favourite beer. It tastes and smells absolutely incredible. This thing has been dry hopped within an inch of its life. The only adjustment I made was substituting the final dry hop of citra for amarillo, which seems to have worked really well.
[b]Dry hopping - siphoning[/b]
If you're dry hopping into either primary or secondary, you'll need to siphon the beer out at some point into your bottling bucket (unless you've got taps and filters on all your FVs). This can be a nightmare when you've got a heap of loose hops in there, so I devised a free and easy filter to go over your siphon.
I'll try to stick up a photo later, but I basically wrapped a wire coat hanger around a tube which was 1" diameter to make a wire cylinder (about 4 inches long) and then put a few tight twists in at the top (around a pencil). I stick the wire cylinder and the foot off of a clean pair of tights (mrs pf doesn't know, ssshhh!) into some boiling water for 5 mins, then pop my siphon tube down through the tight coils (which holds it in place) and down so that it sits a centimetre off the bottom of the wire cylinder. I then pull the tight material over it like a sock and secure at the top with a zip tie.
Then I simply push this contraption into the FV and let it sit just off of the yeast cake. It works really really well, with no reduction in flow for the full volume of the FV, even with a mountain of hops in there.
Posted : 07/02/2014 1:49 pm
Nice links, thanks!
Just stocked up on malts and hops as it happens. Got some crushed chocolate to try out for a change. Latest effort was a crushed crystal and Goldings affair. Not 100% sure yet, as it's conditioning in the bottle, but I may have slightly overdone the hopping. Nice and clean, clear beer though, and pre-conditioning sample went down well.
Posted : 07/02/2014 2:05 pm
Is this the place to ask for an idiot's guide? I have absolutely no knowledge but wanting to start brewing my own. We live in France and struggle to get any proper ale! One thing I think might be a problem is that we lack anywhere cool...this was a problem when we tried home-made cheese.
At present wanting to limit expenditure, but in time don't mind investing a bit.
Posted : 07/02/2014 2:26 pm
[url= http://www.brewerscoop.co.nz/BIAB.pdf ]This[/url] shows you the basics of BIAB. Best advice is just to get brewing and you'll soon learn/research as you go along 🙂
This could be problematic. How warm are we talking? I generally ferment at around 15-18 degrees, which works well for me, but to be honest, most ale yeasts are fine up to around 22 degrees.
You can make a brewfridge on the cheap. Just pick up an old fridge/freezer that someone is throwing away and follow one of the many guides available online for converting it into a unit which will keep a constant temperature inside all year round.
Posted : 07/02/2014 2:30 pm
I just completed my first batch and handed a few bottles off to some friends for their opinions. I'll have another go at it soon but I need to drink this lot first 😉
Posted : 07/02/2014 2:34 pm
That's great thanks. Very very tempting. Shame we recently sold a chest freezer and took an old smaller freezer to the tip....
Would one of your recipes above be good for a first try?
Any online suppliers you can recommend?
Hope you are still enjoying the Highlands by the way.
Posted : 07/02/2014 2:38 pm
I used [url= http://www.brewuk.co.uk/store/ ]these[/url] guys recently and was impressed.
In all honesty, for your first few recipes, I'd stick with something really simple, since it means less to think about, less to go wrong and it will help you identify what ingredients are leading to specific flavours. But, that said, the Sierra Nevada pale ale is pretty straight forward (no dry hopping etc). You could leave out the yeast nutrient too.
Have a google for "first all grain recipe", since I suspect there will be loads of blogs/forum posts with recipes in them 🙂
(as for the highlands...i'll be there in t minus 5 hours... 😉 )
Posted : 07/02/2014 2:44 pm
Is it possible to brew gluten-free beer?
Thanks. 🙂
Posted : 07/02/2014 2:48 pm
cg - yes, I believe it is. not sure how, but I think it's possible
nice idea PF but try here before you go re-inventing the wheel...
http://www.jimsbeerkit.co.uk/forum/viewforum.php?f=5&sid=6325a104841127a7ca3b38c142ee7031
Posted : 07/02/2014 2:54 pm
There's a million recipes online John, the purpose of this was for STWers to share their favourites 🙂
Posted : 07/02/2014 2:58 pm
cool is only really a problem if you want to brew lagers... as long as your fermentation room is below 25C you should be ok for ales
Finished this book the other day. Light hearted and not in massive depth but this guy visited 60 breweries in Scotland but does talk a bit about the process different brewers used:
http://www.amazon.co.uk/Leaf-Paradox-Discovering-Beer-Whisky- [url]ebook/dp/B00DP8S2JU/ref=sr_1_4?ie=UTF8&qid=1391781617&sr=8-4&keywords=the+tea+leaf[/url]
Posted : 07/02/2014 2:59 pm
fair point 😳
actually, come to think of it, I have a few favourites that I'd like to share too...
later...
anyway, there's also this:
http://www.brewmate.net/recipe
lots of repetition there but the "Dirty Celebration Ale" is one of my favourites
Posted : 07/02/2014 3:00 pm
Oh, also, the Open University are currently offering a full online course in the the "Chemistry of Beer" for FREE 🙂
I've already done the first couple of modules...it's quite full on. A background in chemistry would be a distinct advantage!
Slick interface too, it's well put together.
[url= https://janux.ou.edu/landing/course.chem4970.html ]Chemistry of Beer[/url]
Posted : 07/02/2014 3:10 pm
Thanks john. 🙂
Posted : 07/02/2014 3:21 pm
I'd just like to thank peterfile publicly as i've been one of the email lurkers and his advice has been great so far. I haven't brewed any BIAB so far, but i'm really looking forward to it and some of the recipes up there, particularly the SNPA, look awesome!
Second vote for BrewUK here, used them lots and always delivered well. Likewise i think the forum is great over there, haven't been able to identify the "big hitters" yet 😉
Posted : 07/02/2014 3:22 pm
I've got an Oatmeal Stout on the go at the moment, it's one of the best beers I've done in the last 6 years:
Pale Malt 4600g 75.4%
Roasted Barley 600g 9.8%
Flaked Barley 300g 4.9%
Flaked Oats 300g 4.9%
Pale Chocolate Malt 300g 4.9%
Challenger 60mins 32g
Fuggle 10mins 32g
23litres / OG1.059 / 5.2% / 30IBU
Cheers,
Jamie
Posted : 07/02/2014 3:24 pm
Thanks for the heads up, I'll look into that!
Cheers,
Jamie
Posted : 07/02/2014 3:26 pm
It sure is! I've not brewed with it but Spelt can be used as a gluten-free barley replacement.
Cheers,
Jamie
Posted : 07/02/2014 3:29 pm
Ah ha! It's you then 🙂
Jamie, that's quite like an oatmeal stout I did recently, I had some black malt and carapils in there too, with northern brewer instead of challenger.
Posted : 07/02/2014 3:30 pm
If I where to brew it again, I'd add a little black malt- just to give a bit more coffee-ness to it. The fuggles and challenger hops where home grown, now is the time to get planting! If anyone want's some cuttings, just shout.
Cheers,
Jamie
Posted : 07/02/2014 3:36 pm
Thanks jamie. 🙂 This place is a mine of information!
Posted : 07/02/2014 3:40 pm
Jamie, I brewed a [url= http://www.homebrewtalk.com/f12/chocolate-espresso-stout-40754/ ]Chocolate Espresso Russian Imperial Stout[/url] a few months ago. Soooo much fun to brew. It's an enormous beer (about 9.8%), so I think it's going to need 6-12 months to mellow, however I had a sample at the 2 month mark and it's coming along very nicely.
I brewed some espresso and added to the secondary FV. Think I used 1 shot of espresso per 1.5-2 litres in the FV.
Give it a bash, definitely worth sticking batch down for a while!
Posted : 07/02/2014 3:42 pm
I've been thinking about getting an RIS on the go for ages, it's the tying up of a keg for a year + that's putting me off! It weird, I don't drink coffee, or any hot drinks for that matter, but love coffee-y stouts, coffee cake, tiramisu - I think I'm actually a closet classic STW coffee ponce!
Cheers,
Jamie
Posted : 07/02/2014 3:53 pm
bottles!
Posted : 07/02/2014 5:07 pm
bottles!
Faffage!
If I am bottling I tend to bulk condition in a Corny keg then once dropped clear then rack into bottles.
Cheers,
Jamie
Posted : 07/02/2014 5:19 pm
yeah they're a faff but on the other hand, if one goes 'off', you only lose 500ml. If your keg isn't properly cleaned, you lose the lot...
Posted : 07/02/2014 5:43 pm
First time Brewer, Woodfordes Wherry, Bottled up last Sunday, Looking forward to results in 9 days and counting!
Posted : 07/02/2014 5:52 pm
I'm just waiting for my third batch to be ready for drinking. Only standard kits so far but really enjoying it so far.
Also have some wine that I'll be bottling this weekend. Not sure how long to leave that before drinking. I'll try a month.
Posted : 07/02/2014 6:27 pm
[b][u]Dirty Celebration Ale[/u][/b]
Original Gravity 1068 Final Gravity 1014
Colour (SRM / EBC) 9.5/18.7
Bitterness Alcohol by Volume
64.3 IBU 7.0%
Brewhouse Specs
Recipe Type All Grain / BIAB
Batch Size 20L
Boil Time 60min
[b]Fermentables[/b]
Pale Ale Malt 4.61 Kg
Munich I 0.92 Kg
Carared 0.25 Kg
Wheat Malt 0.25 Kg
Caramunich III 0.12 Kg
[b]Hops[/b]
Name Amount Use Time
Nugget 27.24g Boil 60 mins
Amarillo 19.74g Boil 15 mins
Cascade 19.74g Boil 15 mins
Centennial 19.74g Boil 15 mins
Amarillo 19.74g Boil 5 mins
Cascade 19.74g Boil 5 mins
Centennial 19.74g Boil 5 mins
Amarillo 19.74g Boil 0 mins
Cascade 19.74g Boil 0 mins
Centennial 19.74g Boil 0 mins
[b]Yeast[/b]
Safale US-05
[b]Mash Steps[/b]
Saccharification Rest 60.0 min 66.0 °C / 150.8 °F
Posted : 08/02/2014 12:26 am
Cheers,
Jamie
I'd gratefully take some cuttings off you but I think I'm a bit far away (Manc). Love the idea of planting some rhizomes but not sure how the reality works out - do you not need some serious trellis work?
Posted : 08/02/2014 12:42 am
Started this two weeks ago insane Belgian Quadruple for a mates 60th bday in September
going to bulk condition it in a cornie then bottle into 250 ml bottles
a sipping beer I think
Alien-Evil-60
Belgian Dark Strong Ale (18 E)Type: All Grain
Batch Size: 23.00 l
Boil Size: 25.81 l
Boil Time: 60 min
End of Boil Vol: 23.92 l
Final Bottling Vol: 23.00 l
Fermentation: Ale, Two Stage
Date: 23 Jan 2014
Brewer: Troutie
Asst Brewer:
Equipment: Trouts equipment
Efficiency: 72.00 %
Est Mash Efficiency: 72.0 %
Taste Rating: 30.0
Taste Notes:
Ingredients Amt Name Type # %/IBU
5.00 kg Pale Malt, Maris Otter (5.9 EBC) Grain 1 45.5 %
2.00 kg Munich Malt - 20L (39.4 EBC) Grain 2 18.2 %
2.00 kg Vienna Malt (6.9 EBC) Grain 3 18.2 %
0.25 kg Acid Malt (5.9 EBC) Grain 4 2.3 %
0.25 kg Carafoam (3.9 EBC) Grain 5 2.3 %
0.25 kg Caramel/Crystal Malt - 60L (118.2 EBC) Grain 6 2.3 %
0.25 kg Melanoiden Malt (39.4 EBC) Grain 7 2.3 %
1.00 kg Candi Sugar, Dark (541.8 EBC) Sugar 8 9.1 %
60.00 g Goldings, East Kent [5.00 %] - Boil 90.0 min Hop 9 21.2 IBUs
50.00 g Tettnang [4.50 %] - Steep/Whirlpool 60.0 min Hop 10 7.4 IBUs
2.0 pkg SafBrew Specialty Ale (DCL/Fermentis #T-58) [23.66 ml] Yeast 11 -
Gravity, Alcohol Content and Color
Est Original Gravity: 1.108 SG
Est Final Gravity: 1.016 SG
Estimated Alcohol by Vol: 12.3 %
Bitterness: 28.6 IBUs
Est Color: 82.8 EBC Measured Original Gravity: 1.106 SG
Measured Final Gravity: 1.010 SG
Actual Alcohol by Vol: 12.8 %
Calories: 1040.6 kcal/l
Mash Profile
Mash Name: Single Infusion, Light Body, No Mash Out
Sparge Water: 9.75 l
Sparge Temperature: 75.6 C
Adjust Temp for Equipment: FALSE
Total Grain Weight: 11.00 kg
Grain Temperature: 13.0 C
Tun Temperature: 6.0 C
Mash PH: 5.20 Mash Steps Name Description Step Temperature Step Time
Mash In Add 26.08 l of water at 71.9 C 64.4 C 75 min
Sparge: Fly sparge with 9.75 l water at 75.6 C
Mash Notes: Simple single infusion mash for use with most modern well modified grains (about 95% of the time).
Carbonation and Storage
Carbonation Type: Bottle
Pressure/Weight: 135.29 g
Keg/Bottling Temperature: 21.1 C
Volumes of CO2: 2.3
Carbonation Used: Bottle with 135.29 g Corn Sugar
Age for: 30.00 days
Storage Temperature: 18.3 C
Notes
Created with BeerSmith
Posted : 08/02/2014 6:35 am
Damn it Trout that sounds dangerous!!
I'm still using my massive brewery stuff, great way to start!, getting the hang of things now and producing some nice bitters.
I started out trying to do all sorts of recipes and clones but I think mastering a standard brew is fairly important, you can see what you're doing wrong or where you can improve.
Got to start looking into water treatment and controlling fermentation temperatures next!
Posted : 08/02/2014 7:37 am
It was only meant to be 11% but ended up at that though not yet got an ending gravity.
cheapest way for fermenting temp control is a large builders bucket and a fishtank heater surround the fermenter with water and set the thermostat on the fishtank heater and leave somewhere that is not too hot
[URL= http://i199.photobucket.com/albums/aa46/amticoman/Home%20Brew/2013-03-10141655.jp g" target="_blank">http://i199.photobucket.com/albums/aa46/amticoman/Home%20Brew/2013-03-10141655.jp g"/> [/IMG][/URL]
second way is a insulated cupboard and a 50 watt greenhouse heater controled by a STC digital controller
[url= http://www.ebay.co.uk/itm/Digital-STC-1000-All-Purpose-Temperature-Controller-Thermostat-Aquarium-w-Sensor-/181006904049 ]STC 1000[/url]
[URL= http://i199.photobucket.com/albums/aa46/amticoman/Home%20Brew/2013-06-21200133.jp g" target="_blank">http://i199.photobucket.com/albums/aa46/amticoman/Home%20Brew/2013-06-21200133.jp g"/> [/IMG][/URL]
Then a more complex way is a fridge with heater and STC 1000 to heat and cool if needed
Posted : 08/02/2014 8:58 am
other than a campden tablet in the water to get rid of any chlorine, treatment may or may not be necessary, depending on the quality of your water to start with.
I've never treated my water other than the campden tablet; so far it's worked fine without.
I'm doing a BIAB demo at my LHBS tomorrow and the owner normally uses a bit of gypsum & epsom salts when he brews at home, but doesn't bother when he brews at the shop. seems to work for him as well
Posted : 08/02/2014 8:57 pm
Trout, that cupboard looks great, I hadn't though of insulating mine. My cupboard never goes below 14 degrees in winter, but can sit at 25 in summer, so my biggest battle is trying to keep it cool. Any ideas other than having to build a fridge? I've not go space for that at the moment.
I just opened an oatmeal stout that I bottled a few weeks ago. Expected to be a bit wild at the moment, but it was fantastic! I can't see how it could improve that much over time, but if it does then I'll be a happy man! Really straight forward recipe, nothing special, but just came out really well. Will post the recipe up when I get home.
Posted : 10/02/2014 8:46 am
Hi Gary,
PM me your address and I'll and get some cut, probably at the weekend. Nothing fancy needed to train them, I simply extended a fence panel using 1m lengths of 1"x1/2" timber and zig-zaged garden wire / bailer twine up the panel and posts. Hops grew really quickly, once they get going tuck them round the wire / twine everyday.
Cheers,
Jamie
Posted : 10/02/2014 11:40 am
Hey all, great thread and as always its surprising how many common interests span STW and the depth of knowledge that exists here 🙂
tacopowell, welcome to the world of home brewing! As a complete novice myself (brewed my first wherry last June) I can suggest the most important skill to master (IMO) is patience! I bottled a festival IPA in July and it was fully 4 months before I felt it was at its best. It’s like a punch in the face from a grapefruit, not unlike Punk IPA but a lot less refined than that. Still my best kit brew to date although I would definitely recommend the Festival beer kits range over any others I’ve tried (albeit the only others I’ve tried are Woodfordes kits)
Luckily my garage store is a mile from my house (sister’s garage) so the immediate urge to drink beer is tempered by a 15 minute round trip to get it... I find with almost every kit brew I've done they taste a lot better after 3 months, but I’ve still noticed the homebrew "twang" which is why I’m thinking about dabbling with BIAB 🙂
In terms of the brewfridge there is a great guide on building a temp controller based on the STC1000 mentioned by Trout on the previous page. Even a mildly competent DIY’er and a few bits scavenged here and there can make something that looks pretty good and works really well. I managed to pick up an old fridge from freecycle, reinforced the bottom shelf and jammed the temp controller probe and a 60w greenhouse heater in there and it will keep my brew within 0.5 degrees for the life of the fermentation. One tip - make sure the probe is well insulated on the side not touching the FV otherwise the controller will start hunting i.e. fridge cools below threshold it so immediately starts heating, heat rises quickly above threshold so it turns the fridge on to cool etc. As some have said it might not be top of the list for a novice brewer but I really liked putting the project together and I think maintaining a steady temp can only be good for the brew.
Link to the [url= http://www.brewuk.co.uk/forums/viewtopic.php?f=3&t=2804&hilit=stc1000 ]thread[/url] on BrewUK here, which is an excellent source of info and people on there are helpful too.
Sadly last weekend’s project didn’t go quite to plan 🙁 I decided to have a go at building a wort chiller out of copper. I’d managed to procure the copper coil at a reasonable price from a local plumbers' merchant and found a paint can approx. the diameter that I needed, but it wasn’t tall enough to wrap the copper all the way up. In the usual style of “if in doubt, flat out” I set about it on the kitchen floor and actually got on quite well until a momentary lapse in concentration produced a slight (note slight) kink in the tubing. Cursing myself I carried on to about 95% completion, but the kink was bugging me already. I’m sure more than a few of you are aware of the gnawing, nagging sensation that it’s just not 100% right and once you acknowledge this debilitation condition all rational thought goes out of the window 🙂
The reality was the kink was so slight I could have left it, or just squeezed it gently with pliers to sort it but no, I had to do something about it. After confirming the external pipe bender I had would never get to it in a million years (it was about 1/3 way up the coils) I foolishly decided to unroll the coil and start again. BIG MISTAKE. The project rapidly unrolled in front of my eyes, figuratively and literally. The coil began kinking at every turn, probably because I’d moved out of the relative warmth of the kitchen into the cold garden and the copper did not take kindly to being bent a second time. Cue lots of huffing and puffing, muttered swearing and a few slaps for the shed, then the whole 10m coil of copper was consigned to the recycle bin. Needless to say I was raging at myself for a: attempting it without having everything I needed to get the job done properly and b: letting a pretty insignificant event derail the whole thing and cost me £16.
Needless to say I’ve learnt my lesson and have a couple or revisions to make before I attempt it again.
We’ve all been there when the screwdriver is good enough to do the job, then it slips and gouges the frame…..
Anyway, that’s my painful weekend experience laid bare so I feel at peace now and ready to move on. Keep the great tips, advice and recipes coming.
PS peterfile that RIS sounds magic and Trout that death cocktail you posted sounds scary awesome! 🙂
Posted : 10/02/2014 12:14 pm
can anyone post a link to that micro kettle kit that was posted up on here just before christmas? it was 99 quid or something like....otherwise whats the basic kit required to progress from two can kits as im doing now to all grain...I obviously have a fermentation bin and pressurisation barrel and hydrometer ect.
Posted : 10/02/2014 12:24 pm
http://www.massivebrewery.com/index.html
do it....
Posted : 10/02/2014 12:29 pm
donks - Member
That video John posted upthread is a guy brewing-in-a-bag. You basically just need a vessel big enough to boil enough wort for your needs, and a bag to hold the grain. A pillow case shape basically - stitch together a big sheet of viole from a fabric shop, cost a couple of quid.
A typical 25L fermentation is going to need ca. 34L of water to start with, so that's a big old pot sitting on the stove. If you've got one of these already, plus a decent hob, then great. It's easier to use a dedicated boiler, though, with an electric element - like a giant tea urn. This will run you best part of £100.
Posted : 10/02/2014 12:38 pm
It's quite hard to keep the temperature right on an Aga, by the way! 🙂
Posted : 10/02/2014 12:40 pm
Cheers Clobber.
Might have to purchase one of these just to ease me into the process. Have read some of the older posts on this system and so far i gather my ceramic hob may be a bit crap, so as an alternative i have a 2 ring camping stove in the garage which may be better plus the steam and smell would be confined to there leaving my kitchen and wife well out of it. Will this be ok..this should be fine?
Posted : 10/02/2014 2:12 pm
Hmmm... can't vouch for the power of your camping stove boiling 10litres... try it first, it might be fine...
I have a gas wok hob on my cooker and it powers it beautifully... And I love the smell of boiling wort in the kitchen... Missus, kids and dog not so keen...
I think the massive set-up is a great way to start, you will want to upgrade eventually but it answers a lot of questions.
Posted : 10/02/2014 2:43 pm
Agreed in full.
One thing I would suggest is to buy a second/third FV bucket. That way, you can spread out the fermentation to bottling times nicely, and build up a decent stock of stuff conditioning in the bottle, as well as having a failover if a brew goes wrong!
Posted : 10/02/2014 2:46 pm
Page 1 / 16
