Zee brakes
Pads Ubercomponents sintered
Amongst a host of other things decided to change the brake pads, first decided to use the RWD pads I got at the Ard Rock put the pistons all the way in flush with he callipers and the pads were basically touching each other and there was no way the rotor was going through that.
Put some Uber pads on and struggled to get the wheel back on as well .. basically the pads are touching the rotor. Same situation with the rear wheel was pretty bloody stubborn and had to open another set.
So do I just suffer the pain of them rubbing on the rotor till they wear down or is this going to have an adverse effect on the rotors or do I pull them out and sand them down?
For the record have been using Uber pads in the past without this issue.
Any thoughts much appreciated apart from buying genuine zee pads at a slightly eye watering price.
