I’ve got a pair of SLX M675 brakes and the pads are pretty much gone. Instead of the finned pads they came with I’ve bought G01A resin pads without fins.
I thought that there was a little air in the system so prior to fitting I popped the yellow bleed block into the calipers, attached the bleed funnel, added mineral oil and pumped out some air which should have left the system air free.
Having fitted the pads the levers are really firm and I can’t adjust the calipers to that the discs won’t drag on the rotors.
Do I have too much oil in the system or do I just need to let the pads wear in? This is the first pad change I’ve done on the SLX brakes.
