bodged pop lock con...
[Closed] bodged pop lock conversion?
[#3867084]
Have removed remote pop lock thingy from my reba fork today as the return spring is ****ed, it doesn't get used enough to bother a proper repair.
I can just twist the adjuster, but it'd be easier with a "tab" to grab I reckon.
Was thinking of wrapping a cable tie around the adjuster to do this but this won't work. Has anyone bodged this another way?
Posted : 13/04/2012 12:07 pm
 LoCo
Put a bolt with decent sized head into the cable retention grub screw hold. 😉
Posted : 13/04/2012 12:10 pm
Or just use some epoxy or jb weld stuff to glue a tab onto it.
If the return spring is ****ed then there shouldn't be much force required to adjust the compression and the glue should hold fine.
Posted : 13/04/2012 12:22 pm
nice one, cheers both. A.
Posted : 13/04/2012 12:26 pm
if it's pop loc then the lever does the locking not the fork....is it the spring in the dial on the fork that has gone?
Posted : 13/04/2012 12:27 pm
I just slipped an O ring onto the groove for the cable.
Posted : 13/04/2012 12:28 pm
I used a washer held in place by the grub screw for ages. Did the job.
Posted : 13/04/2012 12:30 pm
nomakoman - yes that's the spring. I read about them being trouble and figure I can live without.
cheers for extra options folks, I have a spare rubber loop with tab from an sks mini pump holder that might do the trick...
Posted : 13/04/2012 12:38 pm
if you undo the right hand leg top you can pull the red damper assembly out and unclick the end of the spring with a screwdriver, then it is totally manual from the cap. there is an online Peterpoddy guide somewhere
Posted : 13/04/2012 12:46 pm
Yup, and you can replace the top cap for the Pike one with a tab ...
Posted : 13/04/2012 1:55 pm
nice one, just ridden MCR to Glossop on the Trans Penine without the remote, and the spring wasn't returning it when I changed the position so I think it's already disconnected.
Posted : 13/04/2012 5:52 pm
^ is anyone brave enough to click that for me?
Posted : 13/04/2012 7:19 pm
It links to a pdf called poplock conversion, and has pictures and text of how to do the conversion.
Or it could be hard core leprechaun porn...
Posted : 13/04/2012 7:29 pm
looks like it's the pdf, usefuly, thanks!
Posted : 13/04/2012 9:43 pm
Sorry for scaring you!
I should have said "here is Peter Poddys PDF guide"
Posted : 15/04/2012 5:38 pm
