Right, they’re XTR M985 and it’s the rear brake, the lever is higher than the caliper but roughly the same height as the syringe that’s attached to the caliper.
I’ve got a syringe suspended vertically (attached to a ladder leg) with a bit of hose attaching said syringe to caliper, filled with brake fluid.
I’ve then got another syringe (dunno if it’s relevant but the plunger is intact) jammed hard as poss into the reservoir hole at the lever, also with a substantial amount of brake fluid in it.
I open the nipple (teeheehee) at the caliper 1/8 of a turn and push the plunger of the syringe that’s attached to the caliper, air and brake fluid are forced into syringe at lever.
I then pump the brake lever like I haven’t pumped since I was fifteen and little bubbles drift up through the hose into the syringe at the caliper.
When air stops bubbling into syringe at caliper, I repeat AND IT’S NOT BLOODY WORKING!!!!!
Please, what am I doing wrong?
