I'm the proud owner of a Citroen C4, which for some unknown reason has glass rear windscreen right to the edge of the boot. Which obviously precludes me from fitting a rear rack as the catches cant be fitted on their normal points.
However, I think i've got a solution to this, so thought I'd throw the rack on board to see if its actually going to fit...
But that got me thinking I might need a lighting board since the wheels will partially obstruct the light cluster...
So...
Apart from strap positions, does anyone see any real problems with either of those mountings? I know the first option is a bit high and obstructs the lights, but the second one seems like a go-er... Even if it requires some muscle to get the bikes on it..
