Belt drive users?
[Closed] Belt drive users?
[#1906901]
Had another chain break on me on the way home from work, always carry a chain tool so was able to get going but what a f*%kin mess!! Been very interested in the belt drive for some time. Wondering if anyone has been using one for a while, any drawbacks, any slips, easy to look after? Any thought aprieciated...Im aware of the need to split the frame and issues with getting the front chainring to fit ect..
Thanks a lot
B
Posted : 18/08/2010 1:10 pm
only times i've snapped chains is when they haven't been joined properly.
Posted : 18/08/2010 1:16 pm
i thought i'd snapped a chain last night, turned out i'd snapped the spider instead. much more irritating.
Posted : 18/08/2010 1:29 pm
How are you snapping them? plates or at pins? if so how, are they twisted etc? chains dont just fall apart.
Posted : 18/08/2010 1:32 pm
RIP has a belt drive VN Zion with a Rohloff that he's been running for a couple of months, he seems to like it a lot, I expect he'll be along shortly to tell you about it.
Posted : 18/08/2010 1:49 pm
I have the Trek district. I love the belt drive. I've not put it under severe strain but it has never given me any cause for concern
Posted : 18/08/2010 1:57 pm
Just don't by Sram chains and you'll be fine. It's not something that should ever happen.
Posted : 18/08/2010 2:08 pm
Sorry, can't tell you about the problems of belt drive because I haven't had one yet (18months)
Posted : 18/08/2010 2:32 pm
Single speed is teh answer
Posted : 18/08/2010 2:43 pm
I run a 1x9 on both my commuter and offroader which probably adds to a bit of extra chain strain. Its not happening all the time or anything and I'd be the first person to point to incorrect joining as the cause of many problems.
I do avoid sram chains( the joining link they supply failed quite a few times over the years) Prefer the wipperman joining link.
Come to think of it the chain that broke was an oldish sram..
Anyway would love an oil-less system on the commuter atleast, save clothes and all and ariving in with black fingers....
It appeals to me that the belt would have a really long lifespan aswell..AND IT CANT BREAK!!!
Single speed is the answer Cynical! But not to this question..")
Thanks all.
B
Posted : 18/08/2010 3:08 pm
I've snapped a few SRAM chains, still use them though.
Posted : 18/08/2010 3:15 pm
Belt drive is the answer for commuting. That Trek (district?) is amazing. Belt drive, hub gears, drum brakes (sealed).. all you have to do is fit ride-on cables and you're sorted for a good 5 years. First maintenance item would probably be perished tyres 🙂
I really want one. Did you know it comes with a travel coffee mug to fit into the bottle cage?
Posted : 18/08/2010 3:18 pm
anyone done a belt drive fixie, i cant see why it would make any difference but i'm considering it for the polo bike
Posted : 18/08/2010 3:22 pm
Belt drive fixie?
Posted : 18/08/2010 3:38 pm
molgrips - Member
nice STW comment there...how do you explain the other side of that story?? I used shimano..they split several times and then having changed to sram never again...hhhmmm
kit breaks..sometimes.
Posted : 18/08/2010 4:06 pm
I've snapped all sorts of chains, generally from lack of maintenance or poor joining. Never at a powerlink. Always pulled a plate off a pin, usually at a sticky link that I've not checked out properly, and usually when I'm being lazy and putting power on during a shift.
Posted : 18/08/2010 4:09 pm
I used sram chains and never snapped a chain once in at least 10 years of riding. Not a single occurrence. Sram changed their production facility, and it started happening - I was gobsmacked. Then I switched to whatever brand my LBS sells (I forget currently) and normal service is resumed.
They were all outer plate failures btw, never a powerlink. And I never split my chains either (except via powerlink) because I know it makes them weaker.
Posted : 18/08/2010 4:14 pm
JonEdwards - Belt drive fixie?
is that ? supposed to be there?
if it is, I dunno
if it isn't, is it yours and how does it ride?
Posted : 18/08/2010 4:28 pm
surly cross check with alfine, no problems yet. very very smooth
Posted : 18/08/2010 7:04 pm
As the man said, single speed, next to zero maintenance.
First thing i've replaced is my tyres, after just over 1500miles on London mean streets they were ****ed, need brake blocks next as the OE Tektro ones are near shot, but again 1500 miles in all weathers with mucho stop starting - mushnt grumble
Posted : 18/08/2010 7:23 pm
Combine the belt with a S-A 3 speed and you have a silent bike, and no more maintenance than a single speed.
Posted : 18/08/2010 8:24 pm
"It appeals to me that the belt would have a really long lifespan as well..AND IT CANT BREAK!!!"
It may be tough, and have a good life span but it seems unlikely it "can't" break. Belt drives in other environments including car engines wear and fail. They may have a long lifespan, but I know of someone who had a timing belt in their car snap less than a month after having it fitted. Wrecked the engine. I know its a different environment, but "can't" still seems improbable.
Posted : 18/08/2010 10:24 pm
