back wheel came off...
[Closed] back wheel came off!
[#3264061]
built up an orange five and took out for a shake down test. all good, 1 hour ride, struck for home and had big off. face down watching my rear wheel fly overhead and away. pride, knees and ankles grazed. but how come the back wheel can remove itself that easily? QR could have been loose, but surely the vertical mounting and the chain works against the cassette/axle to keep everything somewhere in the right place.
anyone with past experience and advice please?
Posted : 20/10/2011 6:55 pm
that's about it really, nothing else doing the job of holding it in there
Posted : 20/10/2011 7:02 pm
Maybe not done up properly in the first place.Always check its properly tight and it wont happen again...
Posted : 20/10/2011 7:16 pm
What was the QR incidentally? (If it was a Shimano, you did it up wrong. If it's Hope, you probably didn't 😉 )
Posted : 20/10/2011 8:00 pm
...did you bounce much then?
Posted : 20/10/2011 8:31 pm
Is'nt that just how orange fives ride. Skinned knees and rear wheels rolling around all over the place the last time I went to a trail centre.
Posted : 20/10/2011 8:36 pm
I forgot to do my qr up once as well.....my advice would be not to do it again.
Posted : 20/10/2011 8:38 pm
Northwind - Member
What was the QR incidentally? (If it was a Shimano, you did it up wrong. If it's Hope, you probably didn't )
POSTED 2 HOURS AGO # REPORT-POST
It was shimano. Think you're right. Must of worked loose and lever was probably not positioned well
Posted : 20/10/2011 10:34 pm
Shimano basically don't work loose if you fitted it right (unless broken o'course but I've got one from the 90s that still works better than most new QRs)
If you have a Hope Pro 2 hub, you could consider switching to bolt-in... You've got 2 points of engagement there and both need to come loose/not be tightened before the wheel can come out.
Posted : 20/10/2011 10:48 pm
Yeah had my rear wheel drop out with shimano QR, going over a drop off which was pretty interesting - god those XTR mechs are tough! as the bike landed on it and is still fine
defintly do it up tight and on the rear make sure the lever is pointing away from the direction of travel, then any stones, sticks etc are unlikely to open the lever when they invariably hit it
Posted : 21/10/2011 12:11 pm
Discovered that the nut around the axle close to the disc was loose and with the slight offset action of the hub, it had probably made the qr work loose. so check those nuts!
Posted : 21/10/2011 4:52 pm
Northwind- shimano hub. Qr in forward direction and loose. Plus my last post = catastrophe
Posted : 21/10/2011 4:55 pm
