Avid elixir R - any...
[Closed] Avid elixir R - any good?
[#1486976]
Better than XTs? Feel? ease to work on?
cheaper anywhere than Merlin at £160 for the pair inc rotors?
Posted : 07/04/2010 3:53 pm
there good when they've been fitted properly.
took me a month to realise that part of the caliper casting was hitting the bevelled washers and knocking it all askew every time I bolted them up.
sorted now thanks to a bit of filing
Posted : 07/04/2010 4:03 pm
Mates got some and very pleased with them.
Edit: he got them on the Merlin offer 🙂
Posted : 07/04/2010 4:09 pm
Pricey for what they are, I think XT are better made, but they're a very nice feeling powerful brake.
Posted : 07/04/2010 4:12 pm
I really like my CRs, when they work. Had a few reliability issues, but the Rs are probably more reliable as they don't have the stupid pad contact adjustment feature, which doesn't work anyway.
Posted : 07/04/2010 4:14 pm
Very nice one-finger braking on my Boardman HT. Good modulation.
Posted : 07/04/2010 5:09 pm
I like mine but they are known to have problems with the bleed from new. Unfortunately a bleed kit is £35! Fortunately it works really well and once you have done it a few times you can do a full bleed with fresh fluid or a new hose in under 10 mins.
They are great when bled and I prefer mine to my old mono M4s.
Posted : 07/04/2010 5:55 pm
Love mine - been faultless for 18mths - bleeding first time round is a bit of a faff but once you know what you're doing it's a doddle
Posted : 07/04/2010 7:32 pm
 bol
Best brakes I've used. Luckily they aren't niche enough for some, so you can usually get some great deals on barely used sets on here.
Posted : 07/04/2010 7:57 pm
I have a brand new set of CR's going
Posted : 07/04/2010 8:02 pm
how much? oh and emailed you 🙂
Posted : 07/04/2010 9:03 pm
I've got a set of the D'a & they are pretty good - although I had to bleed the rear from new. Pad replacement loads easier than.the Juicys.
Time will tell if the piston stick like they do on my Juicys a. it.
Posted : 07/04/2010 9:06 pm
 beb
echo many of the comments here - lovely brakes, powerful and much much better modulated than juicy's. More linear and less grabby. Pad replacement is a doddle. I have also had the same problem with bad factory bleed on my rear brake, but once properly bled they're great.
In the past I've run 2-pot (non-servowave) xt's, 2-pot saints (same brake), hayes, juicy's, formula oro bianco's and these are my faves. For info I weigh 11.5st and with 203/185 rotors they're plenty powerful enough for alps use on my pitch too.
If you do get some you can get cheaper bleed kits from red dog racing which work just as well as the avid ones (used both)
Posted : 07/04/2010 9:19 pm
very good brakes, no issues with mine. Except they tend to squeel a lot when cold.........anyone else managed to sort this out?
Posted : 07/04/2010 9:41 pm
Sent you an email GeeWavetree.... And updated my profile as my email was wrong 😉
Posted : 07/04/2010 11:41 pm
The plastic reach adjusters tend to seize. A couple of sets I sent off to fishers for a warranty fix for this came back un-bled. Otherwise they're a nice-feely strong brake.
Posted : 07/04/2010 11:53 pm
Like mine but they can be a bit, well, bloody noisy. Ok once they have had some hammer and warmed up though. Do be prepared for some faffing getting them set up straight and centered though.
Posted : 08/04/2010 12:07 am
Right - took the plunge and ordered some 🙂 will be with me tomorrow!
Posted : 08/04/2010 8:17 pm
