fitted some avid elixir 5. broke them in riding to work and back, all on rode, braking lightly so they didnt get to hot and warp the discs. after braking in they had loads of power, maybe even to much for the riding that i do.
used them off road today, was fine at the start of my ride but a few hours later on the way back to my car the rear started to get noisey, it sounds like a turkey gobble but only does it under light and medium braking, anything hard and it does not do it as the wheel locks up.
have set up the caliper and pad gap correctly so leaves with thinking its either the pads or the discs? the discs are g3 clean sweep, 160mm f+r. i do have some g2 discs that are also new, they are 203mm front and 185mm rear which im going to try. when the brake is making this noisey the lever feels very notching, like the pad is catching in the holes in the disc as it goes over them?
any body have this issue before? manage to sort it?
sam
