Anyone any good wit...
[Closed] Anyone any good with technical drawings?
[#3916823]
[url= http://farm8.staticflickr.com/7190/7116545413_191cc3e050_n.jp g" target="_blank">http://farm8.staticflickr.com/7190/7116545413_191cc3e050_n.jp g"/> [/img][/url]
Any idea what the dividing sign means in the above?
Posted : 26/04/2012 8:50 pm
is it not the tolerance? so + or - the number
Edit: sorry didn't look closely at the left number
Posted : 26/04/2012 8:52 pm
surely the + and the - is the tolerance?
Posted : 26/04/2012 8:53 pm
As shorty says, what's it for?
This thread needs Mrs Toast. And a bike, a bear and a rainbow.
Posted : 26/04/2012 8:54 pm
Cutting a hole in a worksurface for hob
obelus denotes a range
Posted : 26/04/2012 8:56 pm
denotes a range
Naa, its a Hob he said, not an Aga.
Posted : 26/04/2012 8:57 pm
At a guess it's chamfered so the hole is wider at the top or bottom?
Posted : 26/04/2012 8:58 pm
is it italian by any chance ?
Posted : 26/04/2012 8:59 pm
480 to 490 +2 to -0 tolerance
Not sure what the context is, but it makes no sense to me - unless they're suggesting a size range between 480 & 490 but then the notion of a tolerance (can't read it clearly, but it looks like plus2 / minus0) would be nonsense. Couldn't begin to tell you why they've used the division symbol though.
I'd ring them and ask them for clarification; as the drawing's pants.
Posted : 26/04/2012 9:00 pm
It's a neff hob.
Confused because why not not write 486 +- 6 rather than 480 to 490 +2 - 0
Posted : 26/04/2012 9:13 pm
another neff [url= http://www.neff.co.uk/cpimages/927211.pdf ]drawing [/url]
Posted : 26/04/2012 9:20 pm
Why don't you just measure the hob and see what size of aperture you need that way
Posted : 26/04/2012 10:17 pm
[url= http://farm8.staticflickr.com/7192/6970704686_fe3c375c7b.jp g" target="_blank">http://farm8.staticflickr.com/7192/6970704686_fe3c375c7b.jp g"/> [/img][/url]
Just went with the shorter measurment, fits fine (not in middle front to back because worktops deeper than standard and overhang)
Posted : 26/04/2012 10:26 pm
 loum
as oli'd said^^^.
Sloping (by 5mm each end of the hole) face to those cuts.
490 measured on top of the opening.
480 measured underside.
Possiblly?
Posted : 26/04/2012 10:30 pm
