any compact pump b...
[Closed] any compact pump better than Topeak Mini Morph ?
[#1881964]
need something efficient for when out and about ...anyone know of something better (before I order)
thanks
Bill
Posted : 10/08/2010 10:17 pm
The proper Morph is better- I found the mini morph to be only a bit better than a normal mini pump (it's still better though). The proper Morph is one of my favourite bike purchases last year.
Posted : 10/08/2010 10:21 pm
 ton
i use a little alloy lezyne one, it is very good to be honest.
comes with the old type hose connecter.
Posted : 10/08/2010 10:23 pm
Lezyne version of the mini morph (not sure of the name off hand) hv version blows up a 29er tyre double quick time
Posted : 10/08/2010 10:30 pm
 ton
http://www.chainreactioncycles.com/Models.aspx?ModelID=24666
120psi
Posted : 10/08/2010 10:32 pm
Blackburn Mammoth (older model).
Posted : 10/08/2010 10:40 pm
Lezyne Alloy Drive, simmillar to the one Ton linked above. Very well made, & the reversible connector hose is spot on. Loads less faff than these press on jobbies. 90psi but mine has no probs getting road tyres to 90+.
You still after that stem raiser thing you posted for earlier ?
I've just dug one out in the garage. 1" quill affair with a 1" - 1 1/8" shim.
Posted : 10/08/2010 10:50 pm
I found the mini morph to be perfect
Posted : 10/08/2010 10:52 pm
Topeak Master Blaster Speed Pump - CRC for around £15 - gets my road tyres over 100psi easily and fits both PV and SV. It's a bit longer than the minis but still fits in my camelbak for MTB or downtube for the commute (so cheap though I have two)
Posted : 10/08/2010 10:55 pm
thanks guys
takisawa ygm
Posted : 11/08/2010 12:22 am
Truflo Evolution is the same sort of idea but shifts more air and is better put together. The Plus model comes with a predictably inaccurate guage too.
Posted : 11/08/2010 12:37 am
