Help!
I have an 04 citroen relay with the remote flip type transponder key.
Went to start it yesterday and the ignition barrel was stuck, gave it a bit of persuasion because I was in a hurry and the bugger broke! It's only the key blade that has come away from the fob and it's not jammed in the barrel or anything.
Question 1, if I glue it back together with Araldite metal, will it still work?
Question 2, where can I get a replacement as I only have 1 anyhow. Tried ebay and google but no joy. I'm assuming the dealer will take the pi$$.
Question 3, any ieas why the ignition barrel is stuck? I've managed to free it up a bit with jiggling and wd40,but it still only goes as far as ignition and won't turn the starter. I'm going to try and take it out later for a look.
Thanks in advance for any suggestions
