After reading Boardin-Bobs thread, I thought I might ask about getting my frame to run with a Fox shock also, only I think it might be a bit more complicated
I've a specialized Stumpjumper FSR '07 S-works frame with a specialized shock+brain. It has no lockout or propedal and I'd like them, a boost valve might stop it sitting into its travel quite so much too?
The brain is just too slow to turn on/off, has gone notchy again when turned on and in the off position I don't think is anywhere near actually being off as when it degassed itself (the pressurised nitrogen in the brain) it had way more climbing traction
From the frame manual, the shocks eye-to-eye length is 193.7mm, the stroke is 41.3mm (giving 120mm rear travel)
Might it be possible to have a fox shock (or somebody elses) rebuilt to the original shock/frame dimensions? or is it just too dissimilar to anybody elses shocks?
