Alfine "slippa...
[Closed] Alfine "slippage"
[#1886514]
Had the Alfine on my Scandal since March and it's been great. On the first few laps at SITS it started slipping gears when I applied pressure (usually when climbing) though. Any ideas why this is happenning or what I can do to prevent it?
Switched to another bike after 4 laps for comfort reasons but haven't ridden the Alfine since.
Thanks in advance.
Posted : 12/08/2010 8:40 am
you have the yellow lines lined up in the circled gear right ? - sorry if im teaching you to suck eggs !
also clean cables ? - if it cant release freely due to stuck cables then it will sit between gears ....
Posted : 12/08/2010 8:42 am
 ojom
That is usually the yellow dots as tr says up there.
Also...your chain ok for wear on the chain ring? If not engaging properly it will hissy fit.
Posted : 12/08/2010 8:48 am
My top and bottom sets of yellow dots dont both lieen up at the same time,I use the bottom one for bestest results.
Posted : 12/08/2010 8:57 am
The sprocket isn't slipping round is it? Had that once when it hadn't been fitted onto the hub properly & the three 'splines' were only contacting the hub by half what they should have been & it just slipped round under load.
Posted : 12/08/2010 9:16 am
 MrH
When mine slipped I found I'd kinked the cable when I'd removed the wheel. The small kink acted like a spring and made the hub change gear under load. Change the inner cable.
Posted : 12/08/2010 9:22 am
Thanks for the advice. Will check all these things over the weekend
Posted : 13/08/2010 8:30 am
I had the same thing on my Alfine. I just removed the plastic gear mechanism (twist the grey part to remove) and cleaned the out the dirt from the rear of it. It's been fine ever since.
Posted : 13/08/2010 9:41 am
