I've had it on the bike for a few months now. Seems to be running OK, but I've not touched it maintenance wise. Is there anything I should be doing?
Bike Forum
Alfine Hub Maintenance
Posted 1 year ago #
My understanding is that it is not essential - its supposed to be greased for life. However there is an oil bath available for nexus hubs which will work with alfines as well - use that and it needs an annual lube.
I will go for the oil bath and annual lubes I think with mine
If you find out any more than post it up please. Parts 49-51 on this
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/WH/EV-WH-S500-V-8D-2671A_v1_m56577569830638027.pdfPosted 1 year ago # -
i have 2 alfine's, first one i used for 2 years with no servicing,then watched 18 bikes in hope strip it and oil dip it, runs much nicer now,lots less friction and changes are smoother, the kit from shimano consisting of a plastic tub and a litre of blue oil is £60, you will also ideally need the alfine tool for removing the lockring
i just got an alfine hubbed bike and on speaking to the shop, they say that unless your hammering it in all out grime and the worst of conditions, an annual service ( basically a re-lube ) is all you need for 1000's of miles.
Thanks guys. Just didn't want to get halfway through Mayhem solo and it to seize!
Posted 1 year ago #
Topic Closed
