Alfine experiences ...
[Closed] Alfine experiences please?
[#3734376]
As per the title really.
I am old school 3x9 shimano but am looking at a bike with an Alfine set up.
Any of you run the 1x11 set up? What are they like for performance and day to day riding please?
Posted : 02/03/2012 7:25 pm
Got the 11 and it's fine if you keep the yellow dots lined up, as the cable stretches it's slips a bit.
Also if you live in a hilly area got for the 20 tooth on the back.
It changes nice and under pressure
Posted : 02/03/2012 7:33 pm
Thanks JC
Yes there's plenty hills around here. Are you suggesting a 20t chainring?
Posted : 02/03/2012 8:25 pm
... Are these pretty much winter proof too?
I've got the 8 speed, probably >1500 miles on it. Zero maintenance, however I did clean it yesterday and fitted a new chain.
Posted : 02/03/2012 8:35 pm
Getting the 8 speed was the best bike upgrade I ever did. Running 32:18 off road in the Peak
Posted : 02/03/2012 8:54 pm
No the 20 tooth is on the back (of a 29er) and as long as you dust down the chain once the mud's dried on and lube the chain before your next ride it's perfect.
Posted : 02/03/2012 8:56 pm
I used to have an 8 on the commuter (just sold it a month ago), did about 1500-2k on it, not a single problem.
I also used to have (sold a couple weeks back) an 11 on the mtb. I bought it when they came out. Didnt have any issues in the 1st month or two, then the cable snagged and bent, which ment i couldnt get into 7,8,9 or 10 with out it skipping, a quick cable change and it was fine.
One thing i would say, i did have to fit a middleburn cable oiler as the return spring seems to be not as strong in the 11 when compared to the 8. So i regularly (every 5/10hrs of riding) had to spray a bit of GT85 down the cable. This may not be bad if, like me, you only go on 2/4hr rides but i could see it being a problem on 'all day'ers'. It might just have been an issue with my hub though.....
Only reason i sold both bikes is to get one new one (although it doesnt have an Alfine).
Thanks that helps. As I say it's a very new concept to me ... 😐
Posted : 02/03/2012 9:02 pm
also bare in mind servicing - i know it sounds silly, but while they require 'less' maintaince than a standard mech set up, when the service intervals are up you will either be charged £80ish by your local bike shop, or have to buy the tools and do it your self.
Doing it your self is cheaper, but means stripping the 8 speed and bathing its internals in oil (guides avalible on the web).
The 11 is less invoved, is just a case of sucking out the oil with a syringe and flushing it out with new - however the shimano kit (1no syringe and a plastic pot) costs £70. There is a much cheaper (£24) alternative on ebay which i bought and was fine. Replacement shimano oil is around £12 a service.
Posted : 02/03/2012 9:10 pm
I have the 8 speed. Best thing I've used when it comes to gears
Posted : 03/03/2012 8:29 am
Cost me 20 quid for a full service not 80.
Posted : 03/03/2012 9:46 am
every shop i've asked in Bristol has been around the £80 mark...
Posted : 03/03/2012 9:57 am
I'm clearly paying northern prices
Posted : 03/03/2012 12:17 pm
How easy is it to change chain rings? I can see that they're pretty cheap at about a tenner but want to avoid ruining the set up before I start.
Posted : 03/03/2012 12:27 pm
 kilo
Presume you're talking about the rear sprocket rather than a chainring, if so it's not difficult at all. Undo a retaining clip swap sprockets and then the fiddly bit is getting the retaining clip back on.
should add this is for the eight speed, presumably the same for the 11. I also think the 8 speed is a good bit of kit had no problems from it, off road and commuting
Posted : 03/03/2012 12:36 pm
its the same on the 11.
Posted : 03/03/2012 3:44 pm
I've just been quoted 'about £20' for service and bearing change.
Not bad!
Posted : 03/03/2012 3:58 pm
Great stuff. Yes, referring to putting a 20t sprocket on.
Might just be taking the plunge !!
Will let you know how we get on!
Posted : 03/03/2012 4:28 pm
Been running an Alfine 8 speed on my Surly Pugsley for 2 years now without any problems. And bearing in mind that a high proportion of rides are on sandy beaches and sand dunes with occasional sal****er riding, that's pretty good. My latest Pugsley also has an Alfine 8 speed and my Road bike, a Dawes Ultra Galaxy also got one recently. I run an SRAM 24T rear sprocket, 34T front on both Pugsleys.
Gary
www.pugsley-on-patrol.org.uk
Posted : 03/03/2012 7:42 pm
Out of intrest, what does an Alfine wheel weigh in at ? Anyone ?
Posted : 03/03/2012 8:39 pm
