Having moved house recently my new house has an open gas fire in the living room, coal effect with a marble hearth and back plate finished with a wooden surround.
With the cold weather over Christmas I has noticed that the fire lets in quite a lot of cold air when not used. The metal parts of the fire are freezing cold to the touch
So after turning of the gas I have stuffed paper in the fire flue outlet holes, it reduced the draught. Or so I though…
The draught then emitted from the seal of the fire surround and marble back plate thorough a 3mm gap, taped this…
Now the cold air is now pouring out of the 1mm gap between the wooden frame and wall.
Am I right in thinking that there is something seriously wrong with the fires installation and I need to call an expert before I consider using the fire?
