Viewing 40 posts - 41 through 80 (of 143 total)
  • Your MTB evolutionary dead ends
  • BigDummy
    I really want to count that thing on the Roubaix as a resurrected Flex-Stem. 🙂
    legend
    Needs moar saddle!
    Although I see these making a comeback on new massive ENDURO bikes, with a double dropper setup
    matt_outandabout
    URT’s and other high pivot, stiffens when you stand (fnarr) suspension.
    buckster
    Needs moar saddle!
    Quite clearly more is more. I wonder if flipping the stem would have given an uber aero ride? Some clip on aero wheel discs would not have gone amiss either
    foureyes
    HID lights
    chiefgrooveguru
    Semislick rear tyres with large edge knobs.
    You are not enduro enough! 😉
    mumblemiler
    Still happily using Gripshift in its XX1 format.
    Oval chainrings are now with the larger “diameter” in a different location. Biopace was all to cock!
    mintimperial
    Gripshift?
    Shut your mouth. I love my Gripshift.
    Can’t say I miss bar-ends though.
    ahwiles
    mumblemiler – Member
    the reason ‘why’ is reasonably interesting though…
    anyway…
    this:
    ransos
    dragon
    Plus sized tyres.
    scotroutes
    Steel frames
    Carbon legged sus forks
    A “downtube” made out of wire.
    Nobody mentioned…?
    (oh yeah, Onzadog did 🙂 )
    Duc
    I really like my sub fork and my softail.
    I quite liked my flex stem too and my first gen look spds.
    How about 1.5″ rear tyres paired with 2.1″ fronts.
    slimjim78
    XC
    I do like that someone tried to make a real version of this what I designed years ago
    DrP
    One of the chaps I ride with LOVES and still uses flappy paddle shifters…with uber narrow XC bars.
    Getting on his bike is, well, odd….
    DrP
    mudmonster
    PRST-1
    Andy-R
    I don’t know about a “dead end” – I quite fancy trying a HammerSchmidt on my Liteville.
    Thread hijack, but has anyone used one and was it worth having?
    chiefgrooveguru
    The problem with a Hammerschmidt on most frames is that it’s a granny ring plus an overdrive, so you end up with more anti-squat and loads more kickback. It’ll be ok on some full-sus bikes but not a lot, especially all the 1x specific designs on the market, as pedalling will totally screw up the suspension action and when riding downhill it’ll keep kicking through the pedals and losing grip due to the chain tension resisting suspension movement.
    robsoctane
    Lizard Skin (neoprene) fork protectors – and neoprene brake lever ‘grips’
    rossburton
    What the hell is that?
    Dibbs
    Rollamagig!
    parkesie
    Avid rollermajig
    Northwind
    Cross bikes
    Dibbs
    I had a PRST-1 and a PRST-4, the forks worked well but the spherical bearing on the bottom link needed changing on a regular basis.
    I wouldn’t mind having the PRST-4 back actually.
    Dark-Side
    ABS brakes for a mountain bike
    ac282
    Avid rollermajigs copied the cog hog IIRC. Neither are really a dead end as SRAM have incorporated a roller into their rear mechs.
    newrobdob
    Avid Rollamajigs are great, they solved a problem which later mech design solved. Not needed any more but certainly not a dead end!
    rossburton
    So the internet disagrees over whether it was just a roller to smooth out a tight turn, or actually changed the pull ratio.
    PimpmasterJazz
    Elastomers…
    In general.
    Rorschach
    Moar gears
    parkesie
    Smoothed a tight turn. Its just a roller that got rid of the need for a lasso of cable hanging out back.
    molgrips
    Lol at that ABS abomination.
    Anyway – I really liked dual control.
    scotroutes
    Racks and panniers
    ghostlymachine
    the Internet is full of idiots.
    The one pictured on this thread is a straight roller, there are also a number of different offset rollers available that change pull ratio so you can mix and match shifters and mechs.
    There is also one to enable mix n match between v and canti brake types.
    vinnyeh
    chainstay mounted rim brakes.
    matt_outandabout
    Flouro splatter / swirl Lycra.
    Dibbs
    It certainly is, I think someone is confusing an Avid Rollermajig/Crud Cog Hog with this.
    Shimano even did their own version.
The topic ‘Your MTB evolutionary dead ends’ is closed to new replies.
