The levers are easy enough to strip down and clean. Master cylinder, take off cover and screws and clean. Only one small grub screw holds the lever together, the rest just pulls apart. There’s a tiny rubber bung covering the grub screw (which I think is 2mm hex) about 10mm from the back of the reach adjust screw. Get the bung out with a pick, remove screw, then you can remove the pin that the lever hinges on. You’ll need to remove the bite adjust screw too. The rest of the innards just pull out. You’ll need to poke the piston with something blunt and it’ll spring back out enough to remove it, or use a small allen key an poke it in from the other side where the hose attaches. As long as the piston seals are ok and it moves freely in and out after cleaning, you’re golden. the piston should poke out of the hole about 5mm once you’ve put it back in. The seals tend to swell over time and cause the lever to stop returning properly. Mine are 2 1/2 years old and had that problem with one. New lever time, since spare seals aren’t available.
2 fiddly bits are: getting the lever that acts on the piston for bite adjust back in place can be a bit of a pain and the spring in the lever can be annoying too. Just make a note of the orientation of everything before you take it apart, so you know exactly how it goes back on.
