What Dremel (type) ...
What Dremel (type) tool?
12 Users
20 Reactions
Offline  razorrazoo
Share this post
I’ve finally found a task which looks like it requires a small metal cutting disc type tool (oven fan retaining nut stuck on, I’ve got all the replacement bits but the damn but has seized and I need to cut it off).
I know such tools are going to be a STW favourite so what not too expensive model do I want (which will do my current job, and also be handy for others)?
Posted : 07/06/2024 9:00 pm
Offline  dyna-ti
Share this post
Well Dremel obviously, but more possibly an oscillating Multi-Tool
https://www.ebay.co.uk/itm/196003647483?epid=14033956609&itmmeta=01HZT4YDFVWHRV0CJ83J43E657&hash=item2da2ba4ffb:g:1osAAOSwfA9llWV3
Posted : 07/06/2024 9:04 pm
Offline  razorrazoo
Share this post
Tell me more….
And keen to be pointed to specific models as there looks like there are a lot of things available.
Posted : 07/06/2024 9:21 pm
Offline  Poopscoop
Share this post
I've had an Aldi brand one for years and it's still going strong even after I've totally abused it's usage for jobs its not really intended for.
Posted : 07/06/2024 9:27 pm
Offline  dyna-ti
Share this post
The cheaper model is normally the noisiest, I've a cheap bosch green one and i need ear defenders using it.
This is the old Bosch model(the pro-designated by its blue casing) but despite being 12 years old, its pretty much the same thing. Bosch pro is about 100 quid. I'd always recommend a quality tool over a cheaper.
They are extremely versatile, and probably a lot safety to use for small jobs than buying an angle grinder or circular saw.
Posted : 07/06/2024 10:32 pm
Offline  robertajobb
Share this post
I got a cheapo B+Q random-branded one quite a few years ago.
I always find it deeply frustrating to use as its got sod-all power and slows / stalls too easily.
(Had to use it a fair bit to grind out the pissy crap little Horst Link brgs on the Stumpjumper (as the crap design means they can't be drifted out and always fall apart trying to use an 8mm extractor, leaving the inner races stuck in the frame)
Keep meaning to get a pukka Dremel with decent umpf.
Posted : 07/06/2024 11:29 pm
Offline  Ambrose
Share this post
Whatever you choose, get a cordless model! If you already have other cordless tools, is there a suitable compatible model.
I went down the Makita 18V line a while ago, it suits me just fine for regular DIY work. I have the DTM51Z oscillating tool and have no complaints. The tool is not overly loud but once you get the work piece resonating the workplace can get pretty uncomfortable, wear decent ear defenders.
Also worth knowing (thanks Kayak) is that you can get Chinese? knock-off clones from Katsu that are compatible with Makita batteries. I have the hand held trimmer palm router and for the price it's very good and does everything and more that I need.
Posted : 07/06/2024 11:56 pm
Offline  grimep
Share this post
I've got a Proxxon. Light, quiet, well engineered. Last used it to cut through a steel security rope on one of the bikes in the garage when I lost the keys
Posted : 08/06/2024 11:02 am
dyna-ti and dyna-ti reacted
Offline  sofaman
Share this post
Whatever you choose, wear eye protection.
Posted : 08/06/2024 11:18 am
joebristol, andy4d, silvine and 7 people reacted
Offline  revs1972
Share this post
Full face if using those stupid little grinding disks on a dremel 😎
Posted : 08/06/2024 4:57 pm
Offline  biggee
Share this post
You do realise that most oven fan retaining bolt are left hand thread…
Posted : 08/06/2024 7:42 pm
Offline  Northwind
Share this post
I've had and still have a few, tbh the dremel is the best, and is best supported with stuff (literally everyone else makes things that fit dremels but not all dremel stuff fits other tools). Also the ecomomics tend to work out well with buying a tool + bits from dremel, if you get the speedclick and such included as they're silly expensive otherwise.
The one i use most is a cheap draper 12v cordless, cos it's cheap and cordless. My second one, the first one went on fire a little bit. The cheaper ones can be an amazing buy, sometimes you get a whole big set for barely the price of the bits and discs and such, but equally, the cheap discs especially tend to be really pretty crap.
Posted : 08/06/2024 8:07 pm
Offline  razorrazoo
Share this post
I found out too late, hence the need for a new tool!
Posted : 08/06/2024 9:15 pm
Offline  DT78
Share this post
learn something everyday. why are they left hand thread?
if you use hotukdeals dremels regularly get discounted on amazon. i picked up a 3000 with a big discount. i figured wired is ok for the sort of hobby things i woukd use it for.
also have a proper makita multitool. its brilliant but i wouldnt want to be trying to do small stuff with it
tbh if its a screw on something expensive id probably just use a junior hacksaw and take it slow. cut a slot across so you can get purchase with a flat scredriver
Posted : 09/06/2024 9:54 am
Offline  woodster
Share this post
I've got a basic Dremel, not sure of the model, but with too many old cars it's had an absolute kicking for at least a decade and it still works well.
I highly recommend the Dremel Speedclic cutting discs regardless of which brand tool you go for. You need the little speedclic adapter and the discs are pricey, but nothing else I've used gets close in terms of cutting and durability.
Posted : 09/06/2024 10:11 am
Offline  razorrazoo
Share this post
Went for a Worx sonicrafter cordless in the end due to being able to use batteries with other Worx tools, plus I think for me an oscillating cutter will be more suited to other jobs than a hobby type like a dremel.
Oven fan and motor now replaced and working.  Was easier to cut off the back of the motor to enable a good grip on the fan shaft with grips and then unscrew the nut (the right way) as trying to cut the shaft was blunting the blade (faster than it was cutting - must be some hardened steel).
Posted : 09/06/2024 1:50 pm
Secret Diary Of Benjamin Haworth Age 47 3/4
Last Minute Tuscany
Digital Detox
singletrack issue 159 cover image
Issue 159
