thisisnotaspoon – Member
I always thought (I’m no expert though)
Size – less weight, more reps, several sets, and ont he last one you should be pretty much vomiting, pushing so hard that the bar barely moves, then try and push it another mm at a time untill the pain gets too much, i.e. the more pain you experience in the last rep the more dmage is done and the bigger the muscle grows back.
Stength – big weight, few reps, never do anything to failiure, the idea being you’re doing it as part of a training program, no point being able to squat with 200kg if you can’t ride the bike the next day. The downside of this method and the reason most gym goers go for option 1 is it tends to result in injury if you’re not already doing lots of exercise to have all the strong connective tissue/strong bones etc in place?
POSTED 6 MINUTES AGO # REPORT-POST
That’s it, I would add low weight +very high reps tends to tone muscle, and a middle weight with medium reps adds bulk. For strength “big weight” is not the weight you can get up just about if your technique goes to hell.
Find your 1 rep max (weight you can just do one rep of with PERFECT form) and do close to it. I like to vary the reps and weight per set so instead of doing 6,6,6 at weight X do 8,6,4 at X,X+1,X+2.
Obviously if you want to get strong then unless it’s for showing off at the weight rack then you’ll want to be “usefully” strong. Compound exercises like deadlifts, cleans, squats etc are what you want to be looking at doing. You want to be very controlled and super slow on the down stroke, as it were, and explode on the up stroke (P=F*V, not much use moving a large force (F) slowly (V) as your power (P) will still be low and power is wht you are looking for, for real life applications i.e becoming a faster cyclist/rower/etc.) Your back, your legs and your core (more on this later) are going to be the most useful areas to develop, biceps aren’t. So i’d skip the small exercises only working one muscle at a time, your biceps will get a workout when you do chin-ups, bent over rows etc triceps when you do dips, bench press etc.
Obvious but, structure your workout so the exercises including more muscles (deadlifts, cleans, even chin ups) are at the beginning and more specific exercises focusing on one or two muscles (bicep curls, if you must) are at the end.
Spend a lot of time on your core (infact my opinion on weight training for cycling would be that unless you are a track sprinter get out of the gym, buy a swiss ball, work on your core and ride instead)the more stable your core and the more even the muscles are on either side of your body the better you will perform at basically every thing.
Iain
