van conversion fitt...
van conversion fitting a bed that raises and lowers
19 Users
6 Reactions
Offline  flyinbrian
Share this post
As in the title i want to put a bed in the back of my van so that when im not camping it lifts up out the way so can just chuck the bikes in without removing the front wheel asi will be using the van alot for getting to local day rides. Has anyone any pics of theirs ? Mines a peugeot boxer L3H2 2016 . Even any links to old posts etc which my help because i can find very little info upto now .
Posted : 12/11/2023 7:44 pm
Offline  spooky_b329
Share this post
Technically quite hard to achieve, can you split it down the middle so each half folds up against opposite sides of the van?
Posted : 12/11/2023 7:49 pm
Offline  redthunder
Share this post
https://m.youtube.com/watch?v=5TIva4yePzs
Posted : 12/11/2023 7:50 pm
Offline  jam-bo
Share this post
Stitches and steel did one that lifts up to the ceiling on pulleys.
Posted : 12/11/2023 8:07 pm
Offline  llama
Share this post
Pull out bench bed. Or bench either side with a table/centre slat. Both easy ply projects.
But the problem is you won't want to put mucky bikes in your nice camping van
Posted : 12/11/2023 9:05 pm
Share this post
Mount the mattress on springs fromt he ceiling. Your weight will lower it but in the morning it will spring out the way.
Just don't take any fat chicks home or you may crush the stuff below.
Posted : 12/11/2023 9:28 pm
Offline  db
Share this post
Came here to mention this;
https://stitchesandsteel.com/products/drop-down-carbon-bunk?variant=42318077231343
but beaten to it.
Posted : 12/11/2023 9:35 pm
Offline  mikertroid
Share this post
I’ve just put a Beso bed in the back of my Trafic. Sounds like what you need as it folds flat and you can store it up against the side out the way.
Posted : 12/11/2023 10:33 pm
Offline  dyna-ti
Share this post
dbFull Member
Drop-Down Carbon Bunk
£750 😯
Posted : 13/11/2023 12:54 am
Offline  leegee
Share this post
I'm looking to do the same thing, have a look at folding fishing seat beds.
Posted : 13/11/2023 3:06 am
Offline  thenorthwind
Share this post
4 eye/hook plates securely mounted (that's the hardest bit) to the ceiling. Strong cord/ropes to secure. Additional lateral points to stabilise as necessary. Job jobbed?
Posted : 13/11/2023 6:25 am
Offline  midlifecrashes
Share this post
Hammock. The word you are looking for is Hammock.
Posted : 13/11/2023 8:25 am
dyna-ti and dyna-ti reacted
Offline  matt_outandabout
Share this post
We looked at a set of sailing pulleys to pull the bed up and down. We planned side 'beams' with cross beams in place under the bed, which would locate and so it was then 'solid'. There was nothing to be gained from this - combination of mattress and bed base depth meant you lost headroom, to sleep you had to move bikes/take a front wheel off etc.
We ended up with a higher bed - yes it mean you could not sit up fully, but we could fit 3x bikes with front wheels off underneath it, and due to the slightly triangular shape of the bed we could fit a large 29er enduro bike both wheels on but on it's side underneath. This was in SWB transit.
[url= https://live.staticflickr.com/65535/52216010456_aad580cf88_k.jp g" target="_blank">https://live.staticflickr.com/65535/52216010456_aad580cf88_k.jp g"/> [/img][/url][url= https://flic.kr/p/2ny9GJm ]Transit SWB camper conversion[/url] by [url= https://www.flickr.com/photos/matt_outandabout/ ]Matt[/url], on Flickr
Posted : 13/11/2023 8:39 am
Offline  tillydog
Share this post
^ That's the way to do it.
There's a bloke on youtube who made a lifting one:
Posted : 13/11/2023 9:17 am
Offline  stanley
Share this post
https://www.flatoutcamperbeds.co.uk/
Had a double and now a single. Works well and doesn't take up much room. Think they are called "Folding slide" or similar.
Posted : 13/11/2023 9:22 am
Offline  a11y
Share this post
I've just fitted a Thule MultiLift hoist in our garage to store the roofbox. I see potential in that for raising/lowering a bed in a van. 100kg limit. Yes, could build your own from parts but this works very well and I took the easy option.
Posted : 13/11/2023 9:25 am
Offline  brian2
Share this post
Can't you just keep a piece of 6mm ply to put over the bed? Maybe just slide it under or clip that to the roof when not in use? Mountain to Mohammed and all that.
Posted : 13/11/2023 4:21 pm
Offline  sharkbait
Share this post
Google sailing pipe cot.
Pretty simple, light and folds away.
Posted : 14/11/2023 12:28 pm
Offline  chakaping
Share this post
That drop-down bed looks awesome but does it assume you'll either be using the van for sleeping or biking, but not sleeping with your bike in the van?
Anyway, I'd probably just go with a fold up bed that could be put out of the way - as others have mentioned.
Posted : 14/11/2023 12:51 pm
