Viewing 13 posts - 1 through 13 (of 13 total)
  • Transfering Garmin Map Licenses help?
  • foxyrider
    Here is my quandry:
    Have: Edge 705 with UK TOPO map
    Hopefully getting: New Edge 800
    Sell: Edge 705 Unit
    Need to: Transfer TOPO license to new Edge 800 & remove from 705 to sell
    Initial response from Garmin Support:
    Unfortunately the mapping unlock process only allows for the mapping to
    be used on a specific Garmin device. This unlock information is not
    transferable and will only be useable in conjunction with the Garmin
    device for which it is intended. As a result, if you would like to use
    this same mapping on the Edge 800 it will be necessary to purchase a new
    copy of the mapping for use specifically with this device.
    Am I confused or is Garmin?
    fbk
    Erm….. I believe there are such things as [cough]keygen[/cough] programs on this here interweb for such matters.
    alledgedly!
    having said that, there’s really no need as the GB Discoverer maps on the Edge 800 do turn by turn navigation etc etc.
    Pete
    Can you use openMTB maps on the 800 instead of the topomaps?
    http://openmtbmap.org/
    uplink
    If you were to Google “jetmouse” you’d find all sorts of tools for manipulating maps
    foxyrider
    Yup just wanted to do it legally if possible 🙂
    I got the 50K OS map coming with the 800 just didn’t want to chuck the TOPO in the bin as it were – maybe I’ll just sell it with the 705 then?
    Seems barmey to me – So basically if I broke the 705 or the unit failed I have to buy a new TOPO license – is that not against euro law or something or nuffin?
    gothandy
    Out of interest, what is the best map to buy for Garmin 705, the only option seems to be the TOPO Great Britain no way of just getting South West/Wales for example?
    foxyrider
    Nope Topo GB or European Roads 🙁 Hence why I want the 800 🙂
    stumpyjon
    Try ringing them, They helped me transfer Topo GB from one Vista (which got crushed) to another. I think Topo GB is licenced for up to two devices. I’ve found they’re web help a bit pants but both times I’ve ended up ringing them they’ve been very good.
    gothandy
    Foxyrider I knew there was more too recent sale price of the 705 than just the touch screen of the 800! Just hope the course following function works 🙁
    foxyrider
    Stumpy – fraid not you can tx the license from one unit to another of the same model i.e the old one failed & replaced but not between models. Only one license per Topo was what I was told via web?
    uplink
    It’s pretty easy just to generate another unlock code
    foxyrider
    I’ll give it a go when I get my 800 but they say 705 to 800 requires another license? I am not sure whether we are talking about a pre-installed SD card or the DVD – I have the DVD?
    stumpyjon
    I’d still ring them. I was told if I wreck my lastest unit I won’t be able to transfer the maps to a new unit unless I send the wrecked unit back to them as proof that I don’t have it installed on more than 2 units.
The topic ‘Transfering Garmin Map Licenses help?’ is closed to new replies.
RAFFLE ENDS FRIDAY 8PM
