It was a tough job getting the tyre on in the first place, I needed a tyre lever for the first time in ages. (the one on the back wheel, bought at the same time, went on easy)
I can't rotate the tyre round the rim with no air in it, it grips the rim tape too tightly. I didn't think this was a great problem at the time, I just put a tyre lever in the saddlebag for if/when.
The tyre did rotate round the rim. It pulled the rimtape around too, and after 60-70 miles, they ripped the valve stem off the tube. I had to punch a new hole in the cloth rim tape so the new one would go through. In the middle of a race. rrrr.
Anyone had this happen?
I can't think that there's any other reason for the problem, other than the tight bead. The rim's had quite a few tyres on it, same rimtape, which had never moved before.
Can I stretch it without pulling the bead out of shape? (I thought about leaving it nearly installed on the rim overnight)
Or do I send it back to the shop?
Thanks again!
Did I make worse by running a lowish pressure, so the tyre wasn't bonding with the rim wall as much as it was bonding with the rip tape?
