my thinking was to do as little as possible to f*ck anything up (as well as doing as little as possible)
gotcha, laziness I can identify with 😀
I was hoping someone would answer “I did it and it was fine…”
problem wit that is that just because it was fine for them doesn’t mean if will be for you, as per my original post it will depend on how baggy your chain is already and cage length mostly.
ie: if you’re already running a bit long becuase of lots of chain growth or having left enough for a 34t ring then going todown to 30 and not shortening *might* cause you problems.
But someone else already running the chain as tight as can be on a hardtail could chime in and say it worked for them.
Only way to be sure on your bike is to check and measure everything, could always give it a go and see how you get on and then shorten later if needs be if you really don’t want to split it.
As long as you’re using a split link to re-join it then splitting the chain will have no impact on it’s strength at all as you won’t be re-using any outer plates.
