I’ve got all the shock bolts and bearings out ok with the home brew puller but the shock bushing is so thin it’s very hard to get a washer the right size.
Tried with sockets and vice too but I really don’t want to damage the shock shaft.
Can I just use a junior hacksaw blade to cut a slit then bend the metal away from the eyelet?
You don’t say what make of shock you have, but the Fox DU bushings & aluminium spacers are known for wearing out quickly, so they’ve upgraded to a new “5-piece flanged bushing”. Once you’ve got the old one out, might be worth replacing with the new type. The new one doesn’t need a removal/fitting tool and is reputed to have 50% less friction and last 10 times longer (something to do with the ‘O’ rings in the pic below I’ll wager!).
My 2013 model bike came with one of the new bushings standard, and I’ve ordered another one to fit to my existing bike, which went thru one of the old DU type bushings in six months!
PS: Very useful Fox guide to bushing replacement here and it shows the different types of bushing, including the new 5-piece flanged one.
Be aware that Fox charge £4 for a normal bush. A bush that is in fact a standard part that can be bought for £1 fairly easily. My guess is that the new one above will be similarly over priced.
(same thing goes for Rockshox oil seals which are standard hydraulic ram seals)
I got a bushing tool a few years ago off eBay for about £18, including 8 bushes, from the USA.
The new Fox bushing cost me twelve quid, which is certainly more expensive than a DU bushing. But… remember it replaces both DU bushing, and spacers, and doesn’t need a special tool to fit or remove it, so it works out at about the same price in the end. But most importantly, Fox claim it lasts 10 times longer than the DU bushings, so theoretically you should never need to fit another one!
I’ve already bought a relacement DU one so I might just get tool and go with that – or do I need new spacers too?
Completely depends on the condition of your old spacers. If the surfaces aren’t scored and they fit snugly into the new DU bush then its fine to re-use them. However, if you left replacing the bushing too long so that the aluminium spacers started to wear against the bare metal of the DU bushing, then you’d better replace them.
Do those replace the top-hat spacer bits too?
Where can you get them from? Mojo don’t seem to list them, nor TF, loco etc
yes the du/eyelet bushes are replaced with the cream coloured ‘top hat’ there is the tube which the o rings and spacers fit onto as well, RRP is £33.00 on a full kit for them.
So a polymer eyelt bush and hd bush kit still works out a bit cheaper.
