Hey I’m in real need of some help here,
I recently took my 2×10 X0 setup from an old hardtail and put it onto a new full sus frame. Today when setting it up im finding that when trying to shift into the lowest 2 gears the rear mech is grinding on the metal plate holding the jockey wheels.
I did a little bit of research into this and people said check the chain length, as I’ve just bought a bran new chain I made sure the chain was the correct length for the setup but no…. still the same issue.
The rear cassette is a cheaper Deore 11-32t one. The ‘B’ screw is in fully and now I’m completely out of ideads on what could be causing this since the setup ran fine on the older frame.
I have also changed the rear wheel from a 135 QR Axle to a 12×142 axle. Would this make a big difference?
Any help would be greatly appreciated,
Martin
