I went Hope about 9 years ago becuase I was fed up with fiddling with cone spanners, loctite and replacement shimano freehubs, which never seemed to last offroad. This was LX level kit too.
I have had 6 or 7 different sets and style of hope hub, all have been excellent. My XCs in particular just seem to keep rolling, one set was used daily for 3 years and the bearings lasted 7 years in total. I don’t have to do any maintainence at all until the bearings give out. The hub can then be refreshed using just some £4 replacement bearings, a hammer, a 9″ nail and a piece of threaded bar, with some nuts and big washers. Cheap, easy, quick.
On road bike however, I’m using shimano hubs perfectly happily. Meanwhile the shimano commuter hubs are fairing less well, as the cones seem to keep coming loose and they fill with grit more often than I’d like, nasty noises from the freehub after just 2 years that a strip and regrease did not solve, so I’ll try and find some hope hubs to ‘retire’ to it.
I’ve heard good things about other cartridge bearings hubs, notably goldtecs and the new nukeproofs.
If you don’t want to do any maintainence and they’ll get used alot, I’d suggest cartridge.
