Search the forum using the power of Google
Viewing 18 posts - 1 through 18 (of 18 total)
  • PSA Hayes dominion A4 brakes £95
  • noeffsgiven
    At chainreaction when using promo code SAVE
    bikecurious
    I’m only seeing A2’s. A4’s out of stock.
    bornonaboat
    https://www.chainreactioncycles.com/mobile/hayes-dominion-a4-disc-brake/rp-prod214730
    Bargain price, just be aware that they don’t come with the usual spare pads and the olive is already fitted to the hose.
    noeffsgiven
    Cheers bornonaboat, god knows how bc missed that one, both front and rear in stock.
    blastit
    Can only get them down to 107 . applied code . Have they gone up ?? Still a bargain .
    noeffsgiven
    Still £94.99 when I do it. Based in the UK.
    Big-Bud
    @blastit the deal using the code save is saving you £25 off orders above £100 meaning to get them for £95 simply order the brakes individually ie 2 separate orders
    bikesandboots
    IIRC the retail ones came assembled, with spare olive, spare nut, semi-sintered pads installed, spare sintered pads, pad spacer, and combined bleed block / piston exercise tool.
    honourablegeorge
    Can you cut the olive out and reuse? Or already compressed?
    Will a generic olive and barb work?
    doomanic
    Where do these fall in the 4 pot hierarchy?
    I’ve currently got the choice of Code Rs or SLX.
    hainman
    I’ve heard these are really good brakes
    I’m tempted to buy and swap out for my Saints
    blastit
    Thanks bigbud that works but I’ve ordered at 107 I suppose I could send back
    bikesandboots
    They are Trickstuff Direttissima and Hope Tech4 V4 territory. Above all SRAM, Shimano, Formula, Magura, and TRP.
    stompy
    I just ordered…… 118€ and end delivered to Croatia with the ‘SAVE’ code.
    Had to order separately for the code to work on each brake….
    arogers
    I haven’t tried Formula or Magura but have owned all the rest, plus Hope tech3 V4, and agree Hayes are another level.
    darksideby182
    I have these on my hard tail and have to agree that they are really good especially at this price. Super powerful and with good modulation/feeling.
    mactheknife
    OP, that’s an awesome spor there. Been wanting a set of these for a good while. £95 each end is a steal.
    Ordered!!
Join Singletrack From Only £12.501/2 Singletrack Offer
Use code HELLO54 when you join us as a print or digital member and your membership will be half price for the first year.
The Print+ membership where Singletrack magazine drops through your door, plus full digital access, is normally £45, now only £22.50 with the code. And a digital membership where you can read all the digital magazines is normally £25, and now £12.50 with the code.
Simply use code HELLO54 at checkout.
(New annually renewing membership only. Excludes Gift Memberships, Discount applies to first year. Cannot be used in conjunction with other offers, or when switching memberships)
