Viewing 33 posts - 1 through 33 (of 33 total)
  • Project Bogey: COMPLETE (warning contents contains excessive awesomeness)
  • therealhoops
    When TRH jnr MkII arrived I knew I would need a project to keep me sane during the never ending months of no riding and sleepless nights. I saw a Norco Charger frame on here and started to dream. That was ten months ago. Yesterday I finally finished Project Bogey.
    go on, take it in.
    and t’other side. Here’s the front.
    and from behind (sniggers)
    gold and cash green
    home made dual ring
    drive
    total cost £1053.63 and it fuuuuuurrrrking light for just over a grand. From the ride round the block I can confirm it’s a whipper snapper as well. Makes me look good 🙂
    racing_ralph
    that is, at best, **** ugly!
    MrGreedy
    Nice choice of backdrop 🙂
    Shame about the barends though
    rOcKeTdOg
    yer bar ends are upside down, pretty chainring
    racing_ralph
    home made double ring – do you mean you removed the outer ring??
    cynic-al
    Bar end fail, MASSIVE TIME.
    Otherwise…sorry but it is pretty minging.
    hels
    Nice color ! But yes the bar ends really do have to go before you ride it in public.
    DrP
    Someone also stole your saddle padding….
    DrP
    maxray
    I thought they were upside down but didn’t want to say incase I had been wrong all along!
    esselgruntfuttock
    Yes, very not nice.
    Don’t worry though, i like Orange 5’s
    shinsplints
    It would be half as light without those bloody bar ends.
    I agree the chainrings look puurdy.
    Hairychested
    Nice seatpost and saddle, wheels too. Shame about the colour. Kudos for the Gripshift!
    Militant_biker
    Interesting blend of drivetrain parts – I see X.0, Alivio and some ‘SIS’ Shimano…
    Not my cup of tea either but I’m sure you like it
    cinnamon_girl
    Bar ends are cool! Just ignore that lot, what do they know? 🙄
    Chain rings definitely look good!
    cynic-al
    Jesus THEY ARE ON UPSIDE DOWN
    robhughes
    why…just why…. 😆
    robdeanhove
    No less than 4 errors!
    Bar ends are definitely upside down (and really shouldn’t be on a riser bar)
    The chain is too long (more weight to be saved!)
    Front brake hose running around the outside of the fork – error (should be on the inside, this would not only protect the hose from scuffing and crushing damage, but the hose could be shorter and lighter)
    Rear brake hose is too long
    Possibly a fifth: Is that bits of cable outer between the cable stops to simulate a full length outer? Not only will it add weight (the outer is heavy steel), but it won’t protect from dirt ingress as the dirt only get in at the ends & joints, it will even increase the friction in the bits with “extra” outer. This is a massive fail if my eyes are right.
    OOPS!
    jools182
    Bar ends need to go. Nice colour though
    GaVgAs
    barends on risers?…nooooo 😡
    james
    Bar ends are definetely upside down, and on riser bars. Stubbyish bar ends can look okay, mostly better on flat bars, but anything with a bend in really detracts from a bike IMO
    If you really must have them, and don’t want to buy any more, then try removing the plastic bungs from the ends, take a hacksaw (or angle grinder etc) to the bar ends just below the bend, clean up and square off with a file, reinsert the plastic bungs and you have some stubbyish bar ends, slightly lighter and less eye-scaring than they used to be
    XC717 discs?? Rebas?? Elixir Rs, eggbeaters, XO carbon, yet alivio (square taper?) cranks and no name front mech? I’m confused
    Frame looks a bit odd though. The angles and BB drop almost look as if ought to have a taller fork?
    Andyhilton
    I don’t understand why there is a kawasaki sticker on it.
    ScottChegg
    That took months? Really?
    juan
    To make it look cool… A bit like kawasaki bikes. Fugly as hell, soulless as a possible but green to increase the me me me factor.
    Bike is nice, just need a flat bar, a bigger fork and a longer stem.
    turboferret
    What’s going on with the front mech cable? Almost looks as though it’s been converted to rod actuation in the 6th photo!
    Cheers, Rich
    Bez
    Makes me look good
    Anything would look good next to that.
    xiphon
    Fail.
    crazy-legs
    Cables need sorting and you need a black seatpost to match the stem. Chain is too long as well.
    ChunkyMTB
    Those kawasaki racing stickers are naff. Bit like those £50 bikes you see with Reebok or Coca-cola branding on.
    KINGTUT
    This is a wind up isn’t it?
    ir_bandito
    you need a different front mech. Top-swing/bottom swing. whatever;s the oppposite of what you’ve got there. Keeps the cable snug
    Apart from the bar-ends, I quite like it.
    therealhoops
    rocketdog, cynic-al, maxray, robdeanhove, james et al
    YOU ARE ALL WRONG MMMMWWWWWWWAAAAAHHHHHHHHH HAHAHAHAH HAHA HA
    The bar ends are Codas from yonks ago and are most definitely NOT on upside down. I thought the 42t SIS front mech was a clue that I might be using some uber retro stuff but you all failed with your bike history. You can argue about the looks, fine, but they are on the right way.
    Robdean – you have a keen eye! in my defence: bar ends – you’re wrong, see above 🙂 chain length – this lenght so I can use all the gears that rear cassette is massive, f.brake hose – granted but never had a prob in past, r.brake hose – granted, Alivio – granted but it is HT1 so not as heavy as you think also I have issues with current outboard trends. Frame angles – blame Norco, defo a 100mm fork.
    respec’
    smiffy
    The front mech height will not help.
    epicyclo
    Looks like you enjoyed building it and there’s a bit of thought gone into it.
    The main thing is to go out and get it filthy now.
The topic ‘Project Bogey: COMPLETE (warning contents contains excessive awesomeness)’ is closed to new replies.
