I’ve done a whole house (5 bed 4 bath) in plastic, except where the boiler and cylinder is which is all solder copper. There’s loads of types of plastic, some very good some not quite so much, my order of prefernce;
Hep20
JG
Then the grey stuff if stuck.
Always use the correct inserts – i.e. JG with JG, or Hep with Hep.
I did find that getting a good fit with copper on JG stuff was hit an miss once put under pressure, but after a bit of fiddling it was fine.
There’s loads of old school that bemoan plastic with various horror stories, but it’s like everything, if you do it well (proper*) it will be fine. Also running copper is not always practical and the least amount of elbows in the system the better to avoid pressure issues.
*Clean cut pipe (flat surface), no burs, no swarf and correctly pushed in and tightened (if JG).
