Olympic BMX - gears...
[Closed] Olympic BMX - gears!?!
https://www.bmxnews.com/2021/07/19/bmx-racing-shifts-into-controversy-at-tokyo-games/
Interesting - could we see a close ratio 2sp Shimano groupset soon? Might be good for park bikes.....
Posted : 22/07/2021 6:05 pm
That is.... rad, I think.
Given the 4130 frame has long been dead and buried for meaningful competition and carbon and discs are in BMX racing to stay, why not whack a derailleur on too?
Posted : 22/07/2021 6:18 pm
Been doing start gate gears for years I think, you're only allowed one shift
Posted : 22/07/2021 6:22 pm
There was Browning 2 speed BITD. Never fancied it then.
https://bmxmuseum.com/forums/viewtopic.php?id=807672
Posted : 22/07/2021 6:26 pm
It will certainly test whether Shimano gears can shift perfectly under load!
Posted : 22/07/2021 6:31 pm
Let me get this right...
Gravel = old skool MTB with curly bars.
Now.
BMX = kids bike with gears?
Posted : 22/07/2021 6:49 pm
Premier Icon
matt_outandabout
Let me get this right…
Now.
BMX = Raleigh Grifter
FTFY
Posted : 22/07/2021 8:02 pm
My Dad got me a 2nd hand BMX with 4 derailleur gears back in the eighties. Loved it could escape all the bigger boys trying to chase me!
Posted : 22/07/2021 8:22 pm
Bit disappointed it's nothing more 'factory' than a Zee mech and a shifter on the wrong side of the bars considering its the Olympics.
Centrifugal actuated beryilum sun/planetary gearset in a ti flanged carbon shelled hub sorta thing....
Posted : 22/07/2021 8:39 pm
I'm not into racing but imagine the roof gaps you could do.
Posted : 22/07/2021 9:15 pm
That articles wierd, like it's been written by someone who's never seen/used gears.
Will it survive or blow up? It's a 44t chainring, and it'll be shifting once up to speed, the actual chain tension at that point is going to be really low.
What secret gearing is it? You have a photo, just count it! Does look like a small difference though, which begs the question, why bother? Is ~7% enough to give a meaningfull advantage when the start ramp is that long and steep?
Developed? It looks downright bodged! They've not even used the Shimano mech hanger standard (the one that could make it stiffer and more reliable by getting rid of that top link).
Posted : 22/07/2021 10:25 pm
That brings back painful memories of multiple testicle/top tube interfaces😱
Posted : 22/07/2021 11:05 pm
My Grifter was three speed...
Posted : 22/07/2021 11:46 pm
RustyNissanPrairie
Bit disappointed it’s nothing more ‘factory’ than a Zee mech and a shifter on the wrong side of the bars considering its the Olympics.
Probably pretty ideal, though- Zee's pretty light and has the short cage, and it'll give them production levels of reliability and testedness. It's got a simpler job to do than a dh gearing setup and doesn't need the strength either.
The shifter's pretty inelegant though.
Posted : 23/07/2021 3:29 am
The shifter’s pretty inelegant though.
True - but it'll only need to be used once in a race....
Posted : 23/07/2021 7:13 am
In that picture linked, the chain line looks truly awful though, it would get any roadie having nightmares about the 2 watts of power loss through the chain set
Posted : 23/07/2021 8:02 am
"If Twan runs a typical 44×16 gear ratio, and opts for the 1st gear to be 44×17, he could potentially have a huge acceleration advantage out of the starting gate, down the hill, and down the first straight, then he could shift into his typical 44×16 gear in turn one for the rest of the race. Just speculating on the gear ratios, as Twan has not confirmed what they are."
Speculating indeed as a huge acceleration advantage is not going to be seen by using a 17t over a 16t and within 20 metres you would already be changing up a gear. I suppose the proof will be in the pudding and my money is on it making no difference.
Posted : 23/07/2021 8:20 am
At the last Olympics, the Americans brought a new track bike design with the drivetrain on the left. Whole bunch of sales spiel about how having it there on a team pursuit bike meant better balance as the bike was turning left and leaning inwards, improved aerodynamics blah blah.
It made no difference at all, their qualifying speed/time was way off anything special. But it did get everyone talking about them.
Posted : 23/07/2021 9:13 am
My Grifter was three speed…
they all were for maybe a month, then if anything like my mates, it'd go, easy gear-slip gear-really hard gear as no one knew how to correctly setup a toggle chain.
Posted : 23/07/2021 12:12 pm
Overcomplicated much?
Posted : 23/07/2021 12:18 pm
It's a balance I reckon, getting the gearing right for something like this. If 44:16 is optimum, in that that's what he can push from the gate to get a decent start against others running (probably) the same gearing, then maybe he can use 44:17 to get going and shift up to maybe 44:15 into the first turn? It'd have to feel familiar enough to start the race with so you didn't waste all the gate start practice you've done over the years on 44:16 gearing but just different enough to give an actual advantage. It might work this one time but once everyone else starts using it (like holeshot devices in MX and MotoGP) the advantage is gone and you're at a disadvantage if you don't use it. Also, if he wins gold will he 'only have won because he had gears'?
Whatever, I like it, and as someone said BMX racing is so far removed from its roots (4130, Shimano DXs, CW bars etc...) that stuff like this doesn't really matter to yer average BMXer.
Posted : 23/07/2021 12:31 pm
I'd be surprised of that actually makes it to the start - my money is on mind games.
Posted : 23/07/2021 1:07 pm
 igm
The Di2 version will be betterer. 😉
Interesting they’ve flipped a rear shifter rather than using a front shifter (and yes you could use a front shifter ever though the cable pull is wrong - you just set the smaller sprocket mech position on the limit screws).
Presumably it’s to make it a single shift / release only device.
Posted : 23/07/2021 2:29 pm
or SRAM AXS with a blipper in the grip.
Posted : 23/07/2021 2:32 pm
Going from a 16 to a 17 is big gear change in BMX - would make a massive difference at the level those guys are at.
Posted : 23/07/2021 2:50 pm
It is about 3 gear inches so not what I would call a big change. When first spinning up at say 30rpm the difference in speed between 16t and 17t is less the 0.3 mph and the gear change would have to be soon after that. Really can't see it helping and could just actually hinder as a gear change needs to be thought about/timed etc,.
Guess we will see, if it gets used.
Posted : 23/07/2021 5:37 pm
 scud
I don't know about you, but when i ride singlespeed, the drive to the back wheel feels a lot more direct, in that if i ride 46/16 like i do on my road SS, it feels a lot easier than if i picked same gear ratio on geared bike and tried to stay in that one gear, if thats makes sense, so i wonder if they tiny delay in freehub and geared drive train makes up for the direct feeling of SS?
Posted : 23/07/2021 5:58 pm
Watching the test event at the tokyo track and theres surely scope for a longer gear.
I know BMX always is always furiously high cadence (in the brief moments that pedalling is possible) after the first turn so being able to deliver several high torque pedal strokes vs several dozen 120rpm+ Stokes must be a benefit.
Will be interesting
Posted : 23/07/2021 7:18 pm
When racers change gears they normally go up or down a tooth on the front 44 to 45 or whatever, depending on the track. Going up or down a tooth on the back is a big difference.
These guys are at a monstrously high level - and the race is pretty much over at the first jump. So what you think of as a small difference is actually pretty big in bmx.
Posted : 23/07/2021 8:21 pm
Really can’t see it helping and could just actually hinder as a gear change needs to be thought about/timed etc
Gear change while air pedaling the first double I suppose 😉
Posted : 23/07/2021 8:32 pm
Is it on telly? Will we be able to see it in action?
Posted : 23/07/2021 8:36 pm
My thoughts exactly
Posted : 23/07/2021 9:38 pm
I'd go up a tooth (17t) for starts and drop a tooth for the rest of the track, 44:16 is a compromise between being able to fire out of the gate but be able still spin for the rest.
I'd have thought at the very least they'd have configured a better/simple shifter - it only needs to drop a single gear once (and won't need to upshift).
Posted : 23/07/2021 10:40 pm
Bringing the classic ET trick back out of retirement
Posted : 23/07/2021 11:39 pm
Shimano and SRAM are already working on their new 10-42 2 speed groupsets for 2023.
Posted : 24/07/2021 7:20 am
You can by an original 2 speed BMX rear mech if you want, this idea is not new
https://www.bicycleheaven.org/products/decal-for-schwinn-scrambler-36-36-bmx-bikes
Posted : 24/07/2021 7:51 am
Forum update double post glitch
Posted : 24/07/2021 7:53 am
These guys are at a monstrously high level – and the race is pretty much over at the first jump. So what you think of as a small difference is actually pretty big in bmx.
It is still a relatively small change, especially when the gear ratio is 55GI and the start is downhill. We are not talking track sprinters pulling off with a 100GI.
(I spent almost 10 years riding BMX race tracks, in the olden days when you had to pedal more)
Agree that a small difference can be felt when that is what you ride/practice with and are used to turning/spinning and it certainly makes a noticeable difference across a whole ride on my fixed gear bike when I change by 1 tooth but the actual difference it makes in starting speed on a downhill start with a very powerful sprinter turning 52GI rather than 55GI is the bit I question, would like to see the difference which we will do on 28th July...
Posted : 24/07/2021 8:39 am
I’m sure that the World class BMX Pro and his team know what gearing they should be running and if they think it will break or not.
Posted : 24/07/2021 5:32 pm
44-16 was fine for Harry Leary.
Posted : 25/07/2021 12:11 am
Even our club track has timing from the start to the bottom of the start ramp, those few metres are that important, which is why everyone compromises the gearing for the rest of the track to get their elbows ahead at the start.
So a tiny gearing advantage at the start followed by a tiny gearing advantage for the rest of the track makes a lot of sense, if it doesn't break 🙂
Posted : 25/07/2021 9:25 am
But it is interesting that a tiny (or huge, depending on your view of 1 cogsworth) gearing advantage can't apparently be made less tiny by shifting 2 cogs.
Posted : 25/07/2021 10:40 am
The UCI rule says "Multiple speed gear systems are permitted" in the BMX bit. There's no advantage to being able to shift back down, cos the tracks run slightly downhill and I suppose there's no need to have more than two gears because the races are over in 30s or so and they're in the air or pumping through sections for a lot of that time.
Posted : 25/07/2021 11:05 am
@kayla1 sorry mate when I wrote "cog" I meant "tooth", ie one change, but a bigger one.
Posted : 25/07/2021 11:27 am
But it is interesting that a tiny (or huge, depending on your view of 1 cogsworth) gearing advantage can’t apparently be made less tiny by shifting 2 cogs.
I remain to be convinced that a gear change is going to offer anything as gearing is relatively low already and you get up to top speed of the gearing very quickly/very few metres when starting down a hill. After that it is just brief spins to maintain speed rather than looking to increase speed on the flat.
I would probably like to test it anyway but my BMX race days were 35 years ago!
Posted : 25/07/2021 4:32 pm
but maybe that is because there is only one so it is a compromise gear? Does "relatively low" imply that the optimum gear for during-the-race would be higher?
Posted : 25/07/2021 5:18 pm
Van Gendt got a 1st, 2nd, 2nd in the quarter final heats beaten by his Dutch team mate. Too early for a verdict as they would have won anyway. Have to see how they get on in the finals tomorrow.
As he was world champion in 2019 and had a 5th and 9th at previous Olympics it will be impossible to know what part the gears are playing as he is a realistic contender for Gold already.
Posted : 29/07/2021 8:39 am
The verdict is in, Van Gendt didn't make the final. Maybe he will try 3 or 4 gears next...
Fantastic result for GB though
Posted : 30/07/2021 9:53 am
Yes! Really nice to see Pajon mugging and grinning behind Shriever's interview, too!
Posted : 30/07/2021 11:22 am
Great GB results! Loved how Beth threw her bike down after winning.
It's worth seeking out the unedited full show from iplayer to see how draining a schedule it is and how well they did to avoid what were some horrific looking crashes along the way.
Beth's full unedited interview is pretty funny as well
Posted : 30/07/2021 6:55 pm
So Beth had to crowdfund her way there? ****ing bc.
Posted : 30/07/2021 7:31 pm
 beej
She had to crowdfund for a couple of years I think - from 2017-19. From the BBC story:
In 2019, after her crowdfunding campaign, everything changed when Stephen Park, British Cycling's performance director, recognised Shriever's talent.
He persuaded UK Sport to allow them to re-allocate funding, moving Shriever up to Manchester and bringing her back onto the programme.
"For Sparky to see my potential and give me a chance to be a full-time athlete shot me in the right direction," Shriever told BBC Sport. "Look where I am now."
That seems to be a general issue with UK sport funding - without someone breaking through without central funding, they don't get any.
Posted : 30/07/2021 8:51 pm
So Beth had to crowdfund her way there? **** bc.
4F's please.
Sport UK decide what is funded so athletes can train full time and be supported to go to events. They're to blame for dropping the women's BMX program, not BC, and that's why she had to crowdfund her participation in qualifiers, then BC stepped in again when the potential was realised as the only woman on the program.
If anything BC are the good guys, not the bad ones.
https://inews.co.uk/sport/olympics/bethany-shriever-bmx-gold-medal-tokyo-2020-olympics-crowdfunding-uk-sport-1128218
Posted : 30/07/2021 9:10 pm
