I bought a bike with a single front ring.
I want to put a triple back on the front.
The bike would have originally come with a deore front mech (googled spec)
I determined it needed to be bottom pull and have a 31.8 clamp. I grabbed a bargain second hand X9.
Only it doesnt fit right! 😳
Fundamentally it appears to work but the cable rubs on the BB.
I think i must have the wrong mech-Would a high clamp give me a better cable angle to miss the frame?
Or am i missing the obvious all together?! 😕
Please help! The X9 was cheap,so i dont mind buying another mech, just want to make sure tis right!
I obviously need to know more about gears.
If I had to guess, I’d say the cable guide has been broken off the main bracket. For that sort of set up there’s normally an extension to the guide which passes over and past the bb shell. That’s a bad description but I’m sure someone will post a pic of something similar at some point!
Just had a look at some pics of my old Commencal Supernormal hardtail, which has essentially the same set up. What you get is a short section of plastic tubing that covers the section of cable that passes over the bb shell to stop it rubbing and reduce the friction. This tube slides into the extension from the cable guide under the BB. From your pics it looks like this part might have been broken off. What you really need is someone to post a pic from under a similar frame.
