From what I gather the negative spring adjusts the plushness feel of the fork so more negative air and the fork will push down nice and smoothly. Too much negative air and you will begin to lose travel. I find the best way to set them up is to run slightly less negative air that positive air to retain all the travel but some people prefer to sacrifice 5mm and run extra smooth forks.
A) remove most or all of the negative pressure
B) adjust the positive pressure until you have the desired amount of sag (20%-25% of travel ?)
C) top up the negative chamber and stop just before the fork begins to lose travel. – you may have to do this carefully and a couple of times to get it just right.
ps… PeterPoddy knows much more about these forks than I do so he might have a better way of doing it.
Kev
