Hi all,
Got a document with a bunch of figures, tables etc. Each one has a caption created using the “Insert Caption” tool in References. I’ve also used the “Cross-reference” tool to mention the figures and tables within the text, eg “see Figure 4-5 for an example of this”.
The numbering of the captions is all messed up. From what I’ve seen, the cross referencing all links to the correct figures/tables, but the numbering is not in order. eg it goes 3-1, 3-3, 3-2 etc etc.
Ctrl A + F9 does not fix it, nor does closing and reopening the document (which apparently updates everything).
I understand that for captions inside a text box (ie almost all of them) they need manually updating, but that doesn’t seem to work anyway.
Any tips?
Ta! Duane.
